SoundBlaster Pro 2.0 recapping
    master hoarder
    • May 2008
    • 12175
    #41
    Re: SoundBlaster Pro 2.0 recapping
    Hi Dusko,
    Glad you came back to report your work.
    Originally posted by Dusko75
    The Sound Blaster Pro was super noisy on 2 of the mobos while the other 2 were surprisingly clean, even at full volume (actually, no noise at all). I thought recapping it would get a cleaner sound from the other two mobos but didn't happen that way.
    What kind of noise are we talking about here? Static? Hissing? "Digital" "CPU thinking" noises?
    I know that on certain motherboards, it's a good idea to disable/mute certain inputs (like PC Speaker, CD Audio, and etc.) in the mixer, as some motherboards tends to cause more noise than others and get picked up by those inputs.
    Grounding in the case can matter too. If the case has any plastic standoffs for the motherboard, replace them with brass (or any other metal) ones.
    ... the board looks great but I haven't noticed any major improvements in sound quality, maybe a little more bass but not so sure about that. I'm going to need to do some recordings with my other Sound Blaster Pro (which is unmodified) and compare it to this one.
    Shouldn't really be a difference. The old caps would have to be very bad (especially on the headphone/line output) to make any difference in the sound quality. Also, I don't see many ceramic or film caps, so my guess would be that most of the electrolytic caps on that board filter digital IC power - i.e. where there really is no benefit from special audio caps. Probably even low ESR won't matter either.
    Nevertheless, I would still say this was worthwhile doing, because now you won't have to worry about the electrolytic caps on that card for at least another 15 years.
    I got a ESR meter and the old caps seem fine (@120Hz) but I'm not an expert in electronics and caps are tricky to test, I found a couple of ESR charts online with different values so I don't know
    They are likely OK. Charts probably won't be that much use for these small caps. Reason I say that is because, depending on the cap brand and series, it is okay for some small caps to have quite "high" ESR (that is, relative to larger caps). Even up to 1-5 Ohms for a small 5 x 11 mm cap may still be considered "in spec"... or not (depends somewhat on the series). But for GP caps (i.e. not specifically low ESR), 1-5 Ohms is usually considered "OK".
    I'm still happy about this project, it's something I wanted to do for a long time
    Well, it's always nice to see old hardware getting restored, IMO.
      • Jul 2011
      • 6070
      My Sound Blaster Pro recap project
      Was recapping these sound cards worth the time and effort
      The reason I am asking is a lot of the type mother board that you are referring to are obsolete what are using them for if you do not mind me asking
      I have restored ( recapped power supply new hard drive new cmos battery ) a 8200 elite computer for a battery tester machine that I have that I did not need a up to date computer for it work correctly
      I am about to restore another 8200 elite computer to basically run a 3 D printer that I would like to buy very soon
      I also restoring ( recapped the power supply-[ possibilities recapping the mother board as well ] ) IBM 8183 WGX this computer is older than the other two computer that I was talking about earlier ( I had some real issues getting this computer to work correctly)
      This computer I going to run a Radio Shack volt meter data logging feature that this meter has
      Also use this type of computer to run a Basic Stamp 2 from Parallax
      I use to do Basic Stamp programming probably about 10 years ago I wanting to get back in doing this
      I use to use a Windows 98 computer for this now I going to jump to Windows XP
      I do not think that I could bring back that Window 98 computer back to life ****** maybe
      • Dusko75
        • Oct 2017
        • 21
        Hi momaka,
        Once again, I didn't know you guys replied, weird, I'm supposed to get notifications in my email.
        It's not hissing or static, it looks more like CPU thinking, moving the mouse, apps loading, etc. Imagine if you can "hear the data flowing", that's what it sounds like.
        Yes, only muting the FM (Synthesized music) greatly reduces the noise, no idea how to filter that.
        Yes, there's a couple of brass standoffs so ground is not the issue.
        Yes, that was still a nice experience, I never recapped a board before and I wanted to do that so the SB Pro was a good excuse.
        Thanks for your comments!
        • Dusko75
          • Oct 2017
          • 21
          Absolutely! I never recapped a board before so the Sound Blaster Pro was a great excuse. Also, learned a few tricks desoldering the old caps so whatever the next project is will be faster and easier to do. Anyway, those caps were 25 years old! They may still work but why not refreshing the caps on an old piece of technology that you love and will use!! And.. it looks so beautiful now!
          Yes, they are very obsolete indeed!, I'm using them for nostalgic reasons basically, and being able to play old computer games in the real hardware they were designed for. I collect old computer games so obviously you want to have the hardware too, it's a pain in the a#%! sometimes, this stuff is old and tends to fail. You just have to love it!
          You can emulate all this in a modern computer, I do that too but nothing like the real stuff!
            master hoarder
            • May 2008
            • 12175
            #45
            Yup, that sounds like an analog input picking up noise and mixing it with the stereo out. If using Windows XP and 2000 (and I think earlier versions of Windows have it too), make sure to check all of the volume controls in the control mixer to show up. That way, you'll be able to mute any that you don't need. If that doesn't get rid of the noise, I'm not sure what else is there to try. But that noise is not a sound card fault. It's just either poor PCB design/layout or an input not being muted and picking up noise, as I noted.
            +1
            For me at least, getting the old hardware to work as intended is as much part of the game as is playing the old games afterwards.
            Like you said, this stuff is old and doesn't always work right. Add to that the difficulty in finding the correct drivers and hardware info, along with any possible known bugs... and things can be quite challenging to make these old PCs work right. But I find that usually once everything is set, those old PCs also tend to stay working and be quite reliable too. So they are definitely a labor of love.
            • Logistics
              • Apr 2007
              • 721
              That's an interesting experience, and I'm going to have to suggest recapping all hardware involved (motherboard and absolutely, the PSU) to be sure. When I recapped the portions of my SB16 that mattered (power traces and audio output) I probably, did wrong by using low esr caps in the audio stage as the volume could barely be raised in Windows before it was super loud. But it wasn't noisy. However, I was running on a PIII so design differences are present. I should just send that card to someone on here to play with because I'm not likely to ever use it again.
              • proxneo
                Recapping Sony ICF-SW55 - verifying cap values
                by proxneo
                Dear reader
                I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                At the moment, I have selected replacements based on the following list of values:
                3 x 470uF 10VDC
                3 x 4.7uF 35VDC
                4 x 47uF 50VDC
                8 x 22uF 6.3 VDC
                1 x 220uF 6.3VDC
                5 x 100uF 6.3VDC
                Which...
                06-21-2023, 12:38 AM
              • Green Probe
                Recapping a Denon AVR X6400h SMPS
                by Green Probe
                (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
                Disclaimer: I'm an amateur hobbyist and will get things wrong.
                Always use caution when working around mains power and high voltage capacitors!
                Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
                SYMPTOMS:
                -No display...
                07-18-2025, 03:36 PM
              • TechGeek
                Soundblaster AWE32 (CT3990) and resource conflicts...
                by TechGeek
                Is it just me or does the Soundblaster AWE32 (model CT3990) require a lot of resources to be able to properly run?
                03-14-2023, 09:21 AM
              • slerner
                Recapping KRK VXT6 without original datasheets
                by slerner
                I'm desperate to save my pair of 2007 KRK VXT6 studio monitors, one of which died.
                Hoping for an easy fix, I bought a pair of new-old-stock replacement main boards. I installed one & it was DOA. Tried the other, also DOA. I suspect that 15 years in a Maltese warehouse dried out the electrolytic caps. I tried replacing just the two largest caps, which didn't help. Except to confirm that the old ones wouldn't reach infinite resistance & were a gram underweight.
                Q: How do I match the caps, since there's no series marked on the originals and no circa-2007 catalog or datasheets...
                01-31-2023, 02:21 AM
                Delta DPS-300AB-24b 300 Watt ATX PSU recapping
                by momaka
                Figured I’d separate the recapping details of this PSU in a different thread so that the information can be easier to find. To be more specific, this thread is about recapping of the Delta DPS-300AB-24b, shown here. All details about the build quality of that PSU are posted there.
                Here is the PSU, just to see what we are dealing with:
                And here is a cap diagram:
                Let’s break it down what goes where…
                * 5VSB
                *** cap spot C952: Ltec LZG, 10V, 2200 uF, 10x30 mm before PI coil
                *** cap spot C953: Taicon PW, 10V, 680 uF,...
                04-24-2020, 07:31 PM
