MSI Armor GTX1080Ti_11gb
  • victor-r
    • Apr 2014
    • 48
    • Portugal
    Goodnight
    I need to know the value that normally exists in Ohms in this coil marked with a red arrow, in the attached image, of course between the ground, replace the Smd capacitors that were shorted, now it no longer marks any shorts, but the resistance I think is very low (13.7 Ohms) . Does anyone know the value?​
  • victor-r
    • Apr 2014
    • 48
    • Portugal
    I came to the conclusion that there is no short circuit after injecting 1v and having no consumption (5 mAmp.)
    • RandoomStyle
      • Aug 2022
      • 14
      • Ensenada
      Its going to be on the order of K Ohms
      • narf
        Epson EB-U42 projector / Caps with 0.7 ohms ?!
        by narf
        hi all,
        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
        what i've found so far:
        - the PSU does its job and supplies 12V to the mainboard via the connector.
        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
        - not far away, there's the first cap with a resistance of 0.7 ohms....
        07-02-2024, 03:53 PM
      • gica69
        Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
        by gica69
        I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
        Resistor shows orange range silver gold and green lines.
        Thanks in adv...
        07-21-2025, 09:49 PM
      • harp
        command to run Fn + [left arrow]
        by harp
        I look to find some simple solution to execute Fn+left arrow once at winxp startup... It might be some simple specific command aplication, or batch script, or some C code (I have C compiler, but thats it)... can anyone help with idea or solution? On internet can find some sofisticated programs that can do such things and much more, but I not interested to load it to system for that.... ... ... If you interested in what is purpose... I have some bug or so on my laptop, and on every shutdown reset backlight to maximum, just flash one moment before go off... on next boot backlights is stuck to...
        07-13-2025, 03:39 PM
      • aekie
        Fujitsu STYLISTIC (ARROW Tabs) Q738/SE black screen
        by aekie
        Hi, can somebody help me bios dump or fix my bios for Fujitsu STYLISTIC (ARROW Tabs) Q738/SE. When I switch on, it doesn't show anything on the screen 10 seconds then turn off and turn on loop.
        Here it the original dump
        serial no. : R9Z01531...
        12-17-2024, 09:39 AM
      • Sephir0th
        DELL XPS 15 9560 - No VCore, Power Off after few seconds
        by Sephir0th
        Hello Community,
        i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
        It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
        Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
        I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
        05-09-2021, 11:22 AM
