VP6 Diagram?
  • ChaosBlizzard
    • May 2004
    • 32
    VP6 Diagram?
    Can I get a diagram that shows all 23 caps that are to be replaced on an Abit Vp6? I would appreciate this. As I need one, couldn't tell, but it didn't seem that you can tell what kind of cap it is by looking at it and what not...
    Thanks,
    CP
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    This image shows 19. The remaining 4 are the 1000uF caps right behind the parallel port.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • ChaosBlizzard
      • May 2004
      • 32
      Thank you very much. That layout and extra info is perfect.
      • hs5424
        Dynacord powermate 1600 block diagram.
        by hs5424
        Hi All,
        I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
        The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
        07-31-2025, 01:35 PM
      • gabri2211
        I'm looking for the wiring diagram for led monitor model DHI-LM19-L200
        by gabri2211
        hello everyone, I'm looking for the wiring diagram of this led monitor.
        the model is DHI-LM19-L200, but I think that any other diagram of a DAHUA monitor could be equivalent.
        I really hope that among you someone can help me to repair this monitor, the screen is black, it doesn't seem like a backlight problem.
        I see the presence of 12 volts, 5 volts, but without a diagram the repair is very difficult.
        thanks to those who will answer
        12-10-2024, 04:37 PM
      • Rauni
        Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
        by Rauni
        Hello, this is my first post on this forum, and my first attempted to repair a TV.
        My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
        Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
        Read also that we should test what happens if we...
        10-01-2023, 12:06 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • Stanley1843
        Dell Inspiron 15 3520 - AC Adapter shows "Not Installed - Not Charging
        by Stanley1843
        I bought a used Dell Inspiron 15 3520 laptop and the battery isn't charging. When I go to the BIOS setting it shows that the battery health is "excellent" but on the AC Adapter shows "not installed". I checked the pins from the power connector on the motherboard and I didn't found a short on the PS_ID pin. It dould be the charger (I don't know if this is the original) or what I have to check?...
        09-27-2025, 08:44 PM
