precautions
  • kneedeep
    • Apr 2014
    • 6
    precautions
    I have no experience handling capacitors but I know they hold a charge.
    Do I need to make sure they are discharged before de-soldering to remove them from a circuit?... and how do I accomplish this?
    Anything else I should know to avoid damage or injury?
    • 31090
    Re: precautions
    usually any charge is disipated by the circuit within seconds of powering down.
    it's only a danger on high voltage caps anyway.
    if your worried, just meter the cap pins with a volt meter before you desolder them.
    • kneedeep
      • Apr 2014
      • 6
      Re: precautions
      Thanks!
        03-31-2024, 02:12 PM
      • hans_meier
        HP EliteBook 840 G6 how to dump without desoldering
        by hans_meier
        I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
        01-04-2025, 04:11 PM
      • Dreigas
        ISL95880HRTZ desoldering temperature
        by Dreigas
        I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
        Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
        09-13-2024, 10:59 PM
      • armini
        18VDC PSU completely dead - ZD-915 desoldering station
        by armini
        Hi everyone!
        Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
        Due to a lack of time, I set it aside and didn't look at it.
        Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
        According to replies in 18VDC PSU has dropped to...
        04-25-2023, 07:49 AM
        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
        Securing a good thermal interface between...
        10-07-2024, 04:35 AM
