Lenovo M70Q not booting
  • Chura
    • Sep 2024
    • 6
    • Israel
    I have M70q thinkcentre, that went our of warranty 3 months back, and as expected, its dead now.
    nothing happens when I press power button, tried different power supply, nothing.
    how can I troubleshoot capacitors or what so ever ?
  • mon2
    • Dec 2019
    • 14659
    Hello and welcome. It figures.
    Start with the power path at the DCin power connector. Meter in DC volts mode (30v or higher is ok). Measure the voltage to ground at the PL203 or other ferrite beads. What is the measurement?
    We are only checking if the physical connector is ok to power this motherboard.
    The MAIN power adapter connector appears to be JDCIN4 in the schematic.
    Click image for larger version  Name:	dcin2.png Views:	0 Size:	43.1 KB ID:	3341500
    Click image for larger version  Name:	dcin1.png Views:	0 Size:	49.7 KB ID:	3341498
    • Chura
      • Sep 2024
      • 6
      • Israel
      Thanks for your reply!
      Its showing 20V, all capacitors positive side showing 20v. Also PL201/2/3 the same.
      • mon2
        • Dec 2019
        • 14659
        Check if you have this voltage on pin # 7 of PU201. Measure with care since the board is being powered.
        • Chura
          • Sep 2024
          • 6
          • Israel
          Yellow measure 0v, not sure if its because my needle won't touch. orange should be fine ? also 0v
          • mon2
            • Dec 2019
            • 14659
            Yes, orange is fine. That is a fan out PCB trace that mates with the same contact on this semiconductor. Even the inductor above the orange circle is fine for this measurement.
            • Chura
              • Sep 2024
              • 6
              • Israel
              Its all 0v
              and the VIN (ping #15) has 20v
              so this is the fault ? I read its a " USB Power-Distribution Switches" what its role ? can I replace it at home easily ?
              • mon2
                • Dec 2019
                • 14659
                What is the voltage to ground on pin # 9? This is the enable pin for this USB load switch. If this is a logic '1' = high; then the switch is enabled otherwise the switch is disabled.
                Check if there is a shorted part on this rail. Remove all power. Meter in resistance mode. Measure the resistance with one meter probe on pin # 7, other meter probe to ground (metal shield is ok).
                Click image for larger version  Name:	usb_load_switch.png Views:	5 Size:	224.8 KB ID:	3341719
                • mon2
                  • Dec 2019
                  • 14659
                  Found this:
                  Lenovo ideacentre AIO 3-24IMB05 won't turn on • VLab
                  • Chura
                    • Sep 2024
                    • 6
                    • Israel
                    Pin 9 is getting 3.3v
                    resistance of pin 7 to gnd is 00.7
                    • Chura
                      • Sep 2024
                      • 6
                      • Israel
                      Indeed I get short between ping 7 and gnd, I guess its not suppose to
                      now, how can I identify which SMD cause that ?
                      • mon2
                        • Dec 2019
                        • 14659
                        Correct There should not be a short on this rail.
                        Based on the other post about the same fault, guessing the issue is with a shorted cap.
                        There are a few methods:
                        1) inject a low voltage (1 volt should be enough; not higher) onto this rail and check who heats up with a thermal camera or using IPA (pharmacy alcohol) - the IPA will evaporate faster on the heated part
                        2) use a milli-ohm meter and check the resistance to ground of each part on this rail.
                        3) remove parts to locate the shorted one - every part on this rail is a suspect.
                        Let us try option # 3 - flux and remove PC218 and / or PC219. Then test if the resistance is higher or not after the process. If the resistance remains the same, solder these parts back. Be sure to not create a solder short in the process. You will need flux + tweezers + hot air tools to properly remove and replace the parts.
                        If the short is still present, remove PC213.
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                          LENOVO ThinkCentre M70q ThinkCentre M i5-10400T Specification for Upgrade or Repair
                          This specification for the LENOVO ThinkCentre M70q can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M70q boardview and ThinkCentre M70q schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                          09-12-2024, 02:00 PM
