Can't get drivers for Nvidia V100 32gb Installed
  • Seanathil
    • Jun 2024
    • 4
    Specs
    Ram: corsair vengeance ddr5 16gbx2
    CPU: i7-12700KF
    Mobo: MSI MPG Z690 Carbon WiFi
    GPU: 1660 Super
    OS: Windows 11 home
    First time installing one of these cards for a client, I did a little research, I couldn't find anything about the card not being compatible with my specs, or other requirements the system doesn't have.
    When the card is installed it sometimes shows up in device manager as a 3d accelerator. When I download the drivers from Nvidia they give an error saying no compatible hardware found.
    I've checked bios above 4gb was enabled by default with this motherboard.
    I've removed all video drives and tried reinstalling still got the same error. I tried installing the files manually through device manager. I've tried multiple older drivers and still get the same errors.
    I'm at a loss if anyone has experience with these cards any advice would be much appreciated!
  • mon2
    • Dec 2019
    • 13866
    What are the details of the motherboard? Is the bios the latest? Is the motherboard being over clocked? Restore the bios settings to default. Contact the motherboard tech support to discuss your fault. If the motherboard is flaky on the PCIe enumeration, then the driver does not have a prayer.
    Just spent the last 2 weeks on a similar case with the US Defense dept where a brand new line of HP servers are incorrectly detecting our PCIe adapter designs (Gen1) as Gen2. Due to their bios fault our approved adapters are not being seen by this next gen server. HPE is now reviewing a fix. The plan B is for us to respin the hardware to pacify this non-compliant HP server the client is in requesting.
    • piernov
      • Jan 2016
      • 4435
      • France
      Check hardware vendor/device IDs in Device Manager.
      • Seanathil
        • Jun 2024
        • 4
        Confirmed my bios were on the latest update.
        No overclocking all settings were at default.
        I tried rolling them back to an earlier version and still got the same issue.
        Found these hardware IDs
        • piernov
          • Jan 2016
          • 4435
          • France
          Are you sure this is a genuine retail card?
          1DB8 is the product ID for the V100 SXM3 32GB module, not the V100 PCIe 32GB card, it should have product ID 1DB6.
          1DB8 is not listed as a compatible product ID in the Data Center Driver for Windows 552.74. Dunno if it exists in another driver package, or you can try to select manually the driver from Device Manager and force the installation.
          • R_J
            • 9518
            • Seanathil
              • Jun 2024
              • 4
              I wasn't able to get any of the suggestions to work and eventually gave up and installed Linux, the card worked fine in Linux but was constantly overheating after 30 minutes of use.
              If any runs into the same overheating issue try using this fan: https://www.amazon.com/BFB1012EH-Blo...5583077&sr=8-1
              connected with this 3d model https://www.thingiverse.com/thing:4741583
              • piernov
                NVidia bumpgate
                by piernov
                Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                May complete this post at a later date with more details.
                Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                03-27-2021, 10:34 AM
                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                10-02-2024, 08:52 AM
                NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                10-02-2024, 07:51 AM
                NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                10-01-2024, 01:54 PM
                HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                This specification for the HP ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) boardview and ProDesk 400 G3 MT + NVIDIA GeForce GT730 GFX (2GB) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                09-12-2024, 03:30 PM
