Gpu problem
  • Travis27
    • Jul 2024
    • Philippines
    Gpu problem
    Click image for larger version  Name:	IMG_20240729_123239.jpg Views:	0 Size:	936.0 KB ID:	3318170
    Can i ask what does APW8713 chip do to the gpu?
    It's getting hot when i touch it.
    • 21841
    Post the GPU make and model number please.............
    • trepachka
      Converting HP EliteBook 840 G7 non-touch to touch if possible
      by trepachka
      I am trying to convert a HP EliteBook 840 G7 notebook from a non-touch to a touchscreen. I purchased a complete touch LCD assembly with a screen/back cover/bezel/video cable and swapped it out with the original non-touch LCD assembly.
      The screen works but the touch does not. I know the new LCD assembly is completely functional because we tried it on a similar touchscreen EliteBook 840 G7 and the touch works there.
      I contacted the seller and he said screen conversion like this will not work due some difference in the motherboard for non-touch and touch capable EliteBook 840 G7.
      04-27-2024, 11:15 PM
    • Prott
      Surface Pro 4/5 - no touch after LCD change
      by Prott
      I have a question that's driving me a bit nuts recently.
      Is the touch board on Surface Pro 4/5 somehow married to the motherboard? I have a few Surfaces that, after the touch board change, lost all touch functionality.
      - I tried flashing the bios (simple ME clean from a known good bios, previous bios didn't have an intergrated hub enabled), reinstalling firmware, reinstalling windows and even new touch boards.
      - In one instance, after I tried to troubleshoot by using a known good screen + touch pcb combo on a Surface that lost touch, the touch board...
      01-25-2023, 12:42 PM
    • theone111
      by theone111
      3. Problem: TV shuts down
      07-22-2024, 10:36 AM
    • Zeonalbasta
      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
      by Zeonalbasta
      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
      09-13-2024, 01:17 PM
      Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook Specification for Upgrade or Repair
      This specification for the Dynabook Portege X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR boardview and X40-K, i7-1260P, 14" FHD TOUCH, 16GB, 512GB SSD, T/BOLT, W11P, 3YR schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
      09-07-2024, 05:50 AM
