GV-N2060OC-6GD REV 2.0 GIGABYTE video card troubleshooting assistance needed.
  • gcrezz
    GameConsoleRezz
    • Jul 2024
    • 14
    The issue with this video card is the HDMI port. Specifically on pin 19 (Diode checks on all other pins are normal). When i do a diode check on it from the pin on the board itself, I have nothing. There is also no short on the pin. Resistance reads about 200k. Normally on any HDMI pin 19 I would expect some voltage drop anywhere from .5v to 1.2v but here, I have nothing. The card is operational and can be used via the displayPort ports, but not through the HDMI. Attached you will find the pdf schematics for the card on page 22. I have verified that all of the resistors on this line before the out signal are within tolerance and not blown. Q521 also gives typical resistance readings and voltage drops you would expect of a 3 pin transistor that is not blown or shorted. I am going to try replacing the transistor regardless in the hope that it is not functioning correctly when it senses to 1v8_AON signal. Would explain the lack of a diode reading I suppose.
    Please keep in mind I am not very familiar with graphics card repairs and this is one of a handful I have dealt with with HDMI ports in my experience are about what you would expect as far as measurements and readings on any device. Perhaps I am wrong and no diode reading on pin 19 is normal with video cards? Any help would be greatly appreciated. TIA!
    link to schematic https://www.badcaps.net/forum/troubl...67#post3315767
  • japlytic
    Gigabyte Z690 UD AX DDR4 distingusihing failures+default video
    by japlytic
    On this motherboard with a CPU (requiring discrete graphics) supported by the BIOS (version F3) and a new video card, it has a beep code indicating a CPU failure while the onboard diagnostic LEDs indicate a video system failure and using a different motherboard of the same model had the same result despite confiriming that the new video card along with the power supply as well as the connected display/cable was operational in another system.
    So therefore, I've found that the Video diagnostic LED illuminated before CPU diagnostics were performed and since the CPU has failed, video diagnostics...
    12-30-2022, 11:12 PM
    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
    09-12-2024, 02:00 PM
  • cekcons
    Gigabyte G1 Assasain motherboard Bios IC model or Schematic needed !
    by cekcons
    Gigabyte G1 Assasain motherboard Bios IC model needed !
    Bios ic fried and I cant read the model on top.
    Thanks !
    07-16-2025, 01:22 AM
  • sect-sin
    Gigabyte XT 6800 XT Aorus Master BIOS needed
    by sect-sin
    I have an AORUS MASTER RX 6800 XT (non USB-C version), and my problem is that FUSION RGB is not working, it is not finding the GPU, and the RGB lights are off. There is a new firmware on the Gigabyte site which is supposed to fix this exact issue, but their Firmware upgrade does not work (I just get the highly unhelpful Erasing Flash Failed message when trying to update). I tried various internet-recommended software fixes to address this, but nothing helped, the factory Gigabyte EXE refuses to flash the BIOS.
    My last resort would really be flashing the...
    10-13-2023, 06:08 AM
  • jolivares
    NEEDED IPAD7 A2197 DIODE MESURAMENTS VCC_MAIN, VCC_BATT, VDD_BOOST
    by jolivares
    I sent IPAD 7 WIFI-2019, model A2197 to a techincal service, but they did not repair it, so i am trying to fix it. The problem is the IPAD is not booting and no turn on.
    This is what i found until this moment:
    1) with battery connected, the current draw from the power supply is about 450mA from the charging port.
    2) no short circuit in lines VCC_MAIN, VCC_BATT.
    3) with the power supply, or with the battery, the 3.7V of VCC_MAIN and 1V8_ALWAYS are generated without problem.
    4) the current draw from the power supply, without battery, is about 26mA from the charging...
    07-15-2024, 09:24 AM
