Problem Asus Main Board H110T
  • Rofix
    • Jul 2023
    • 73
    • Italia
    Good morning everyone, I wanted to kindly ask you for advice on this motherboard, Asus H110T unfortunately doesn't turn on, by connecting it to the bench power supply I noticed an absorption of 10mA, and I found 3 coils with 0 Ohm resistance, does anyone have a diagram? I welcome any advice
  • mon2
    • Dec 2019
    • 14659
    This thread should be in the desktop motherboard repair forum but Asus schematics are rare.
    Use your power supply at 1 volt with 3A+ current and inject onto the board where you measure 0 ohms on the inductors. Leave the CPU off the board.
    Search for who is heating up. Hope it is a capacitor.
      SMDFlea commented
      Editing a comment
      Thread moved.
  • anikin73
    • Mar 2022
    • 112
    • singapore
    Did u measure the ohms when u on your power ….?????
    unplug power then measure , if so many shorted, liklely pch is shorted.
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
      by JDC
      ONN 100012588
      Issue: No Power, Then Rebooting After Main Board Change
      Short answer: replace main board and power board
      Technical answer: replace main board and Q306 & Q307 on power board.
      Long answer:
      TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • jimbodriver
      Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
      by jimbodriver
      I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
      Initial results:
      Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
      03-20-2022, 02:30 PM
