Nvidia RTX 3090 FE
  • Aqua_Angel
    • Jul 2024
    • 8
    Nvidia RTX 3090 FE
    Good day there.
    1- I was wondering if i could get the Boardview for the RTX 3090 FE as i just received a GPU but i have no idea what some of the components values are.
    2- Does anyone know the actual smd Resistors that are at the bottom right of the GPU CORE "GA102-300-A1" ripped 2 SMD resistor while doing a service and looking all over the place for the actual value. since i can't get the core anywhere, i will order them from Digikey.
    some say it is a 23 ohm and some say it is a 30 ohm. Not sure which one they are and what are the tolerance,temp and all. i have no clue
    Thank youClick image for larger version  Name:	447206276_1195932614910222_6950912243928990673_n.jpg Views:	0 Size:	487.9 KB ID:	3300592
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    u did not see that is all capacitors?
    • Aqua_Angel
      • Jul 2024
      • 8
      When i use my Multimeter? caps gives me no value, when i use it in Ohm mode? it gives me value. but if they are capacitors? i'm trying to find out the value so i can order the right parts for it so i can bring this card back to life.
      unless you have a RTX 3090 the you could take apart and take the measurement?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3627
        • slovakia
        good multimeters mostly have capacitor measuring mode
        • Aqua_Angel
          • Jul 2024
          • 8
          Still nothing? there is no one out there that has one taken apart that can take the measurement so i can revive my card?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            its only capacitors. i bet most others have simmiliar value. measure others and pic capacity
            • Aqua_Angel
              • Jul 2024
              • 8
              Was able to get the 2 caps that i ripped off another GPU core with the same value. the GPU is back to life. passed all the test on the stress test. i now have a back up GPU. lol
                NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
                The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
                10-02-2024, 08:52 AM
              • piernov
                NVidia bumpgate
                by piernov
                Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                May complete this post at a later date with more details.
                Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                03-27-2021, 10:34 AM
                Thermal pad thickness for various laptop GPU / Graphics Cards
                ASUS Dual RTX 2070 OC 8GB
                ASUS ROG STRIX RTX 3080 OC
                ASUS ROG STRIX RTX 3090
                ASUS TUF Gaming RTX 3080 OC Edition
                ASUS TUF GTX 1660 S-O6G GAMING
                EVGA RTX 3060 Ti XC GAMING 8GB
                EVGA RTX 3060 XC GAMING 12GB GDDR6
                EVGA RTX 3080 FTW3 ULTRA GAMING
                EVGA RTX 3080 TI FTW3 ULTRA GAMING
                EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                Gainward RTX 2080 Phoenix GS Specs
                Gainward RTX 3070 Phoenix 8GB
                Gainward RTX 3080 Ti Phoenix
                GIGABYTE AORUS RTX 3080 MASTER 10G
                02-09-2024, 08:08 AM
                NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
                The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
                10-02-2024, 07:51 AM
                NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
                The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
                10-01-2024, 01:54 PM
