Mac mini 2018
  • sauce
    • Sep 2013
    • 149
    • France
    Mac mini 2018
    I am trying to help someone to repair a mac mini A1993 820-00939.
    The mac mini won't power on.
    Voltages on U7800 are all good except
    PP1V2_PRIM 0v
    PP1V_PRIM 0v
    PP5V_G3S is missing too
    Someone has the power on sequence of this ?
    Thank you on advance.
    Eric
  • sauce
    • Sep 2013
    • 149
    • France
    Sorry forgot to give ohm values on missing voltages :
    PP1V_PRIM => 44 ohm (quite low but I don't know if it's ok)
    PP1V2_PRIM => 5.6k
    PP5V_G3S => > 20k
    • mon2
      • Dec 2019
      • 14657
      Measure the voltage to ground of U7600 (PM_P5VG3S_EN), pin 24.
      If this pin is not a logic '1' (high) then remove all power -> meter in resistance mode. Measure the resistance to ground of pin # 24.
      Also measure the resistance to ground of L7650 (either side is ok) = PP5V_G3S. This is @ 20k ohms?
      The 1v @ 44 ohms is likely ok since it is a low voltage rail. By design, low voltage rails are low in resistance. (As stated by Locutus / Star Trek - 'resistance is futile').
      • sauce
        • Sep 2013
        • 149
        • France
        Ok thank you for your answer.
        So PP5V_G3S must be present when we plug the power cable ?
        • sauce
          • Sep 2013
          • 149
          • France
          So here are the results :
          pin 24 => 0v so not enabled
          resistance to ground very high => 7M
          resistance to ground of L7650 => he says it starts from 0 but rises quickly to few Kohm (he's on Kohm range)
          I ask him to measure U4901 on R4901 pads to see.
          • sauce
            • Sep 2013
            • 149
            • France
            Please someone to help me ? Data is quite important not for me but for the guy.
            • mon2
              • Dec 2019
              • 14657
              Do not frequent this leg of the forum often - usually camped on the laptop side.
              Do replace the coin cell battery.
              Can you share the history of this unit? Any liquid spill? Just stopped working one day?
              Suggest to remove all power -> meter in resistance mode -> check the resistance to ground of each and every inductor on the board. The inductors are usually grey in color and have 2 legs on them. Each such inductor is linked to a local power supply which accepts the external high voltage of ~19 volts ( or whatever it is ) and brings it down to a lower safe voltage (acting like a buck regulator). If there is a short condition which is usually a defective capacitor due to age, the power supply leg will consume higher than normal current and the switching regulator will sense this and for safety - shut it down.
              Again, with no power, meter in resistance mode -> one meter probe (either color is ok) to ground (metal shield is ok) -> other meter probe to an inductor of your choosing. Continue to review each and every inductor. Make a list of any suspects. Then that inductor must be compared against the schematics to understand if the resistance is normal (ie. low voltage rails will have a low resistance) or not.
              PS: Ping me an alert once you are done the above and will review it asap.
              • sauce
                • Sep 2013
                • 149
                • France
                Thank you.
                The mac mini failed during use (the guy says overheat and strange smell) and no water damage.
                The guy must send me the mac mini I known quite well laptops.
                We already measure all coils but no short circuit to ground.
                As I said PP1V_PRIM and PP1V2_PRIM are missing.
                Do you know which voltages I must check in order ? I know laptops but not especially mac.
                • mon2
                  • Dec 2019
                  • 14657
                  Ok, after some strong tea, here is my 2 bits (half a nibble) review on this case:
                  1) you are the 2nd poster with exactly the same fault so this is a common issue.
                  2) the PP1V_PRIM has a rather low resistance to ground so suspecting an indirect or partial short on this line but not a direct one which would be < 10 ohms. This places us in a pickle as we cannot really inject voltage and enough current to cause the shorted component to be identified. Prefer a harder short than 44 ohms to ground.
                  3) in reviewing the netnames, PP1V_PRIM is used to power the analog components of a number of required functions including: USB3 / PCIE2 / SATA2 / PCIE3.
                  Each of these are now suspects for the partial short condition that has caused this power rail of 6A to turn OFF.
                  Click image for larger version  Name:	PP1V_PRIM_consumers.png Views:	0 Size:	35.3 KB ID:	3273247
                  4) Moreso, in the first post, you have observed that you are also missing: PP5V_G3S.
                  In tracing who is a consumer of this power rail? It is the USB interface.
                  Copied below is 1 port on the mac mini - there are others as well.
                  Suspects are:
                  PP5V_G3S_USBA
                  PP5V_G3S_USBC
                  PP3V3_G3S_WLANBT
                  Click image for larger version  Name:	U6700_USB.png Views:	0 Size:	83.3 KB ID:	3273250
                  5) Based on experience, the USB port load switches fail often. Given that a burning smell was observed, do inspect the board for burnt out components and especially the USB A / USB C regions of the board. The USB load switches are supposed to be like a multiple use electronic fuse but they often just fail by burning out. If true, they will tank the interfaces on the USB which will include the ANALOG USB PHY and power rail components. It will be best for you to review the board or at least clear and zoomed up pics of these regions of interest. My bet at this time is that the USB interface has raised this fault.
                  Do ask the owner if they were making use of the USB A interface. USB C interface?
                  PS: We repaired a 5K iMAC with a similar case for a client who took it to assorted shops and could not find the fault. In their case, the bulk cap at the USB load switch was shorted and causing an excessive current draw and tanked the entire operation of the logic board.
                  • sauce
                    • Sep 2013
                    • 149
                    • France
                    Awesome answer thank you.
                    I don't have PP5V_G3S​ because it is not enabled.
                    I don't have the mac mini yet but i will look closer that him because I have a good microscope.
                    • mon2
                      • Dec 2019
                      • 14657
                      The enable can be disabled after the host / master that creates this enable pin has gauged that there is a safety concern. That is the angle I believe that is a fault.
                      • Pragmatiko
                        • Jul 2013
                        • 468
                        • IT
                        PP1V2_PRIM 0v
                        PP1V_PRIM 0v
                        Eric
                        I have almost same problem. To mine PP5V_G3S is present.
                        • mon2
                          • Dec 2019
                          • 14657
                          Do review the voltage to ground of:
                          I2C_PWR_SCL
                          I2C_PWR_SDA
                          PPVBATT_G3_RTC_R
                          Post the measurements.
                          If the above are ok - then for both cases, attempt DFU with Sonoma. Can these boxes enter DFU ok?
                          See the DFU link and the positive feedback here:
                          https://www.badcaps.net/forum/troubl...-liquid-damage
                          * use the above thread to gain the feedback of a very similar fault
                          * use the following webpage to review the need for a DFU:
                          DFU Mode Restore (Macs) - LogiWiki
                          Click image for larger version  Name:	DFU_cases.png Views:	0 Size:	253.2 KB ID:	3274433
                          • sauce
                            • Sep 2013
                            • 149
                            • France
                            I finally have the mac mini !
                            I2C_PWR_SCL 1.8V
                            I2C_PWR_SDA 1.8V
                            PPVBATT_G3_RTC_R​ 2.92V
                            • sauce
                              • Sep 2013
                              • 149
                              • France
                              Just plugged mac mini on my hackintosh and it is in DFU mode.
                              Try revive without success (error 9)
                              • sauce
                                • Sep 2013
                                • 149
                                • France
                                Unbelievable DFU revive with a real mac (I bought to repair it) worked !
                                The mac mini is alive.
                                So DFU and hackintosh even if device appears in DFU mode the revive does not work.
                                Thank you for everyone,
                                • Eniaro
                                  • Mar 2021
                                  • 77
                                  I have 2 A1993, but the one I'm focusing on is the one that won't power on. I'm using the second for comparison because it powers on (overheats somewhere and shuts off). My goal is to try to get the data off it, the one that won't power on.
                                  Usually, dumb luck with board view helps, but the PDF and my little screen isnt helping much. Can someone point me in the right direction? Red is from the board that won't power on, and green is from the board that powers on (black to test point, red to ground in diode mode)
                                  • grimacelord
                                    Mac Mini Late 2018 |A1993| Fan Connector Damage & Lots of Weird Issues
                                    by grimacelord
                                    Hi guys.
                                    I have a customer's Late 2018 Mac Mini in for a ripped fan connector after the customer tried upgrading his RAM.
                                    Some pretty hefty damage occurred because the connector was ripped off entirely including all 6 pads for the fan connector. The connector on the end of the fan itself was also completely ripped off exposing all 6 wires. There is also an exploded component with what appears to be a resistor or filter. Not sure? (See pic). macOS also doesn't boot. Apple logo comes on screen and then moves to the question mark folder. Cannot boot from USB or Recovery...
                                    05-30-2020, 05:52 AM
                                    HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
                                    This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-12-2024, 03:36 PM
                                    HP Stolní počítač 260 G3 Mini i5-7200U Specification for Upgrade or Repair
                                    This specification for the HP Stolní počítač 260 G3 Mini can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Stolní počítač 260 G3 Mini boardview and Stolní počítač 260 G3 Mini schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                    09-12-2024, 02:20 PM
                                    HP 260 G2 Desktop Mini PC i5-6200U Specification for Upgrade or Repair
                                    09-12-2024, 02:15 PM
