iMac Pro 2017 A1862 SSD Upgrade & Recovery mode
  • tommy97
    • Mar 2023
    • 167
    • United Kingdom
    we've got iMac Pro 2017 which having a problem with SSD, iMac come with 2 SSD's 1TB, it was having a problem with the SSD so we get the replacement, installed in and iMac is stuck in recovery mode, tried to restore it & revive, nothing worked - error 4010. After installing old drives now we're having the same problem that the device is in recovery mode. Previously after swap of the SSD iMac worked on the old SSD however after attempt of revive on the new SSD machine stuck in recovery mode, I can go to DFU but the same result with error 4010.
    Any ideas what might've happened and how to resolve that problem?
  • mon2
    • Dec 2019
    • 14683
    https://discussions.apple.com/thread...93?sortBy=best
    • tommy97
      • Mar 2023
      • 167
      • United Kingdom
      Hi, now I'm stuck on the error 9, tried on 1-2-3 ram's, did not change anything, checked on customer old SSD, on the new is exactly the same. (SSD's are installed in the right order)
      • mon2
        • Dec 2019
        • 14683
        PS: How is this thread in the laptop forum?
        Hi. Ditto on the same model in for repair. Were you able to make any progress?
        For our case, the power sequence stops @ PP1V8_S5. This unit will end up in the landfill if we cannot fix it. May try to do a bypass for this PP1V8_S5 rail.
        The PP1V8_S5 appears to be supplied by BUCK3_SW (PMIC @ U7800). Has anyone attempted to replace this part with success?
        Where is the enable for this rail? Is it internal? Can any similar PMIC be used for the replacement?
        BTW - the switching leg of this regulator IS WORKING @ PP1V8_SLPS2R (BUCK3_LX0).
        PP1V8_S5 is not shorted but has 0 volts. This rail powers the flash IC and many other parts onboard.
        Can enter DFU using a remote macbook with proven USB cables running Sonoma but repeated attempts result in Error 9. According to a find on the internet by 'Barry', the DFU issue with Error 9 is a software fault.
        Unable to REVIVE / RESTORE this logic board. Did see a small fan spin during the DFU process.
        Welcome all feedback.
        Click image for larger version  Name:	buck3_SW3.png Views:	0 Size:	95.2 KB ID:	3315983
        Click image for larger version  Name:	power_sequence.png Views:	0 Size:	160.7 KB ID:	3315977
        • mon2
          • Dec 2019
          • 14683
          Suspecting this to be an issue of the host and target OS not matching.
          Tested with many known good USB cables - no difference.
          Inspected the entire board - could not locate a fault. Have not (yet) inspected with a thermal camera but no shorted parts from the hours of debugging.
          Can enter DFU mode with ease using the shorting PCB pads.
          Will roll back the host machine OS and attempt again. We know so far that the target is NOT on Sonoma. About 6 months ago, we did have a client with a dead macbook who was on Sonoma so 'assumed' that the latest and greatest OS is desirable for this DFU process but forgot that this is an Apple design - not much is logical.
          Will update this thread after testing.
          • mon2
            • Dec 2019
            • 14683
            No luck in attempting with an older Configurator on Ventura OS. Same USB timeout error. This makes sense since the CPU / PCH rail is not yet on. The PCH is the host USB controller.
            Also have no VBUS on any of the USB ports yet 5v is enabled on the board. The local USB load switch is enabled by the PCH which is not yet powered.
            If either of the fans is not properly seated inside the molex SMD connector, the local fan will spin at hyperspeed.
            • mon2
              • Dec 2019
              • 14683
              Came across this power sequence charge for the CALPE PMIC which should help:
              https://logi.wiki/images/8/86/820-01...r_Sequence.pdf
              Will continue to review. Issue may be corrupt T2 firmware which is required for a proper DFU. The T2 controller communicates with the PMIC to enable the missing power rails (PP1V8_S5). This is a catch-22.
              • mon2
                In search of T2 rom dump for iMAC 2017 A1862
                by mon2
                Hello all. Have an imac that is not able to create PP1v8_S5 and there are no shorts on the rail. Unable to DFU due to USB not working. Suspecting corruption of the T2 firmware.
                Welcome all suggestions. Thanks.
                08-13-2024, 08:13 PM
              • 944longdrift
                Help Identifying board components - iMac 2017 21.5
                by 944longdrift
                2017 iMac (Mid 2017) A1418
                I'm not quite sure how this happened but a couple of components got ripped off the board when removing from the Logic Board from the iMac.
                Can anyone help identify them?
                I'll have to do the trace repair on the board before soldering on replacements but would prefer to order the components rather than get a whole scrap logic board off eBay.
                Thank u
                03-14-2024, 11:53 AM
              • mat2k
                iMac 2017 PSU - shorted PFC mosfet
                by mat2k
                I am trying to fix an iMac 2017 PSU, initially came with a blown fuse and shorted PFC MOSFET (6R199P). After visual inspection and some measurements I replaced the FET with a P20NM60 and tested with 100w series lamp, and it lasted 1 second before going into dead short. The PFC controller chip (NCP1605BG) and its passives appear fine (passives measure OK), but I do not know if there is a simple way of testing the NCP1605 as I wouldn't like to blind-replace it.
                There was some slight blackening of the solder on the PFC controller passives so I reflowed them all with some flux. I am waiting...
                03-13-2025, 11:31 AM
              • iZakre
                HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                by iZakre
                Hello everybody!
                To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                The thing is that I had installed TeamViewer and could log into the computer...
                02-19-2023, 02:27 PM
              • reformatt
                Intel iMacs, 3rd party SSD failures and Fusion setups
                by reformatt
                I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
                As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
                So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
                12-18-2024, 10:34 PM
