Apple Mac G5 1.8, 20" dual, 600w PSU
  • dashnieuil
    • Jan 2014
    • France
    My first request here and new at this.
    My wife uses an an old iMac G5 which she says she cannot do without! A few days ago it had a power supply failure indicated by an audible POP! On opening the PSU I found that the switch TOP249YN had split in 2 parts with the front section spalling off from the top to about 2/3 of the way down. Could you tell me what would cause this to happen please. I have replaced the part but the board does not power up so there must be something else which has failed to cause this switch to come apart. The board fuse is intact.
    I hope you are able to help,
    Thanks and regards to all.
    Dan. aka dashnieuil.
  • dashnieuil
    • Jan 2014
    • France
    Re: Apple Mac G5 1.8, 20" dual, 600w PSU
    Further to the above this better identifies the problem switch :-
    TOP249YN Power Integrations AC/DC Converter
      Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
      This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-06-2024, 05:30 AM
    • a_p3rson
      Apple Watch Charging Controller Schematics / Boardview - 820-02601
      by a_p3rson
      Hi there,
      I'm looking for anyone who might have information on Apple's embedded Apple Watch charging daughterboard, ID 820-02601. This is currently used by Anker in their Apple Watch charging products, but likely by other Apple partner brands as well.
      You can see the board referenced in ChargerLab's teardown of the Anker Y1811 3-in-1 MagSafe cube - they discuss the "Apple Watch wireless charging circuit" about 2/3rds down the page. It's not pictured, but the board ID reads 820-02601-A, which sure sounds like Apple.
      This daughterboard uses an interesting...
      04-21-2025, 11:41 PM
    • sajidmirza
      Imac pro A1862 switch off after apple logo and half progress bar
      by sajidmirza
      I got a iMac pro A1862 820-00967 in dead conditions, restored in apple configurator successfuly.installed macOS Catalina from internet recovery successfully but after installation it boots with apple logo way to the half of progress bar and shuts down.replugged 2 ssd's of 512GB and cleaned all the RAMs.Still not completely booting.tried PRAM reset but lo luck.Can any one guide me what should I do next.
      07-03-2024, 03:58 AM
    • Natob82
      Micro Momentary Push Switch?
      by Natob82
      Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
      12-21-2022, 05:22 AM
    • grimacelord
      NEC TurboExpress On/Off Power Switch Replacement Help
      by grimacelord
      I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
      I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
      I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
      11-09-2023, 09:49 AM
