Hi guys,
I've just bought this Gigabyte GV-R587UD-1GD cheap (10€) with all it's packaging but of course it's not working. It's in perfect condition, no damage anywhere that I can see. Here are the problems :
- according to the seller, it never woke up from sleep mode
- screen doesn't turn on so no signal
- the GPU remains cold,
- atiflash -i gives a "No Adapter Found" error so the card is not detected (I had some non working cards that were detected by atiflash)
- the voltage seem normal up until I check it past the VRMs where I don't get any voltage anywhere on the board. Both PCI-E connectors are plugged via adapters.
I had similar symptoms with an HD5850 that I repaired earlier this year and it's still running strong in my computer, but a component was broken on this one (a small 5 pin component located near the PCI-E connector). The same compoent on the HD5870 seem intact.
What else would you check ?
Thanks !
Thanks !
