biostar u8638 freeze on boot screen 6d error code
  • srt1
    • Aug 2013
    • 177
    • india
    i have an old motherboard biostar u8638 that freez on boot screening after memory test.error code 6d on post card.is it bad cap issue?i tested motherboard without conecting any other devices such as hdd and cd drive but stl same error also i breadboard. but no success.. please helpo me to resolve this issue i apreciate your answers
  • heavyice
    • Nov 2013
    • 19
    • India
    Re: biostar u8638 freeze on boot screen 6d error code
    check for any carbon accumulation on the SIO, Clock, CPU power IC etc. Re-solder if necessary.
    Try and replace the RAM and then reprogram the BIOS.
    Finally South chip.
    • srt1
      • Aug 2013
      • 177
      • india
      Finally South chip.
      thankyou for your answer. i tried resoldering above mentioned ic and reprogrameed bios chip. but stil same problem. is it south chip bad?
      • srt1
        • Aug 2013
        • 177
        • india
        nobody here for help me? i replaced super i/o .. stil same problm is it dry solder problm in south chip?
        • DynaxSC
          MSI PRO Z690-A DDR4 (MS-7D25) - stuck during boot every second time - debug code 16 & A1
          by DynaxSC
          Hi Folks
          I have an MSI PRO Z690-A DDR4 (MS-7525) which underwent LGA1700 replacement and had a missing resistor in the VRM section. The missing resistor RV170 (49,9Ω) has been resoldered, and I have also replaced a demaged LGA1700 socket.
          Generally the board does boot to Windows, but not always in the first attempt, but after the second attemp to boot the board with Power Button. Also restarting the board from Windows ends up with stuck boot process, but restarting the board again (long push Power Button or switching off and on PSU). Under Windows etherything works
          09-29-2024, 04:27 PM
        • Junior††
          a2251 820-01949-a boot looping after screen replacement
          by Junior††
          not sure how it happened but after replacing the screen on a2251 macbook it:
          fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
          thermal camera shows these are getting quite hot although i'm not sure what do to.
          i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...
          07-15-2025, 09:17 PM
        • arbitarytwist
          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
          by arbitarytwist
          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
          03-01-2025, 01:16 PM
        • FZD
          intel d5400xs, post code 29, no boot
          by FZD
          Hello everyone!
          I am trying to fix an old Intel D5400XS (Skulltrail) motherboard, which gets stuck in a loop on error post code 29 after successfully initialising the RAM and before the next code that is supposed to enumerate the PCI buses (post code 50).
          I should point out that absolutely everything has been tested so far: resetting the BIOS, booting with a single CPU (cross-testing), with a single RAM module (each module tested), changing the power supply, changing the graphics card, disconnecting all peripherals... and that all the components work perfectly on another...
          09-22-2025, 10:30 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
