I do not understand enough about the properties of capacitors. That's why I am asking for your expert's help.
An Amiga 1200 will be long periods unused. I am looking for the best possible capacitors that stays operational condition without active use and do not damage motherboard.
If you can help me, please use Digi-Key's part numbers (I have the group order possibility from there). Thank you very much for your help.
Code:
[B][U]# Location Original Size [/U][/B] 1 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C214"][U]C214[/U][/URL] 10μF 35v (Audio) Bi-Polar 5mm 2 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C235"][U]C235[/U][/URL] 100μF 6v 6.3mm 3 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C236"][U]C236[/U][/URL] 100μF 6v 6.3mm 4 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C237"][U]C237[/U][/URL] 470μF 16v Through Hole 7mm (Lead Spacing 5mm, Height 12.5mm) 5 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C239"][U]C239[/U][/URL] 100μF 6v 6.3mm 6 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C303"][U]C303[/U][/URL] 22μF 35v 6.3mm 7 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C304"][U]C304[/U][/URL] 22μF 35v 6.3mm 8 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C306"][U]C306[/U][/URL] 10μF 35v 5mm 9 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C307"][U]C307[/U][/URL] 470μF 16v Through Hole 10mm (Lead Spacing 5mm, Height 12.5mm) 10 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C324"][U]C324[/U][/URL] 22μF 35v non-polarised (Audio) 6.3mm 11 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C334"][U]C334[/U][/URL] 22μF 35v non-polarised (Audio) 6.3mm 12 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C407"][U]C407[/U][/URL] 10μF 35v 5mm 13 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C408"][U]C408[/U][/URL] 1000μF 10v Through Hole 10mm (Lead Spacing 5mm, Height 15mm) 14 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C409"][U]C409[/U][/URL] 100μF 6v 6.3mm 15 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C459"][U]C459[/U][/URL] 22μF 35v 6.3mm 16 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C811"][U]C811[/U][/URL] 1000μF 10v Through Hole 10mm (Lead Spacing 5mm, Height 15mm) 17 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C821"][U]C821[/U][/URL] 47μF 16v 6.3mm 18 [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C822"][U]C822[/U][/URL] 47μF 16v 6.3mm
