CF-EG65 AMS e-Cube
  • Rayman
    • Dec 2006
    • 4
    CF-EG65 AMS e-Cube
    You can add these Chyang Fun motherboards to the manufacturers who are using bad capacitors. These boards happen to be small SFF motherboards used by FIC, DTK, AMS (possibly others.) I have sold several of these systems in the past and one had problems (random reboots and unexpected system lockups on boot or while in the XP OS) in as little as 6 months. Now, I have had another system come back from the customer (it has been almost 2 years) and all it can do is spin its CPU fan for about a second then it does nothing. I noticed on a visual inspection of the motherboard that three Choyo 16v 1000uf caps around the CPU were bulging and had started to leak. I also noticed that the Choyo 6.3v 2700uf capacitors around the CPU had a brownish stain on their purple sleeves (overheating?). I replaced everything I could on this board with Sanyo caps...but the board still had the same symptoms; I suspect the capacitors damaged other vital motherboard components. The P4 3.2 GHz Northwood CPU and memory was salvaged from this computer. I have managed to get the one with random reboots stabilized for several hours now by replacing the Choyo 16v 1000uf capacitors. I will call it good if it can pass my 72 hour burn in before I let it go back to the customer. I suspect I may have added an additional year (hopefully!) or more of life to the system. I called AMS several times concerning these systems and they say they are obsolete and they can't get parts etc... (always some excuse...) I decided a year ago I am no longer going to build PC's for people because of the unreliable stuff the motherboard manufacturers are putting out these days. I have piles of motherboards with bad caps from (IBM, ECS, ABIT, MSI, GIGABYTE and now Chyang Fun...Shame on all these companies for putting out this garbage.) I have even had boards that started on fire... Well I am done with my ranting; Thank you for reading it.
    BTW Anyone out there know for sure of any motherboards that have good quality components? I used to stand by ASUS but I have seen their name associated with bad caps as well.
    Thanks,
    Rayman
  • linuxguru
    • Apr 2005
    • 1564
    Re: CF-EG65 AMS e-Cube
    I've seen some excellent Powercolor and MSI mobos - with almost all caps being good caps (Rubycon MBZ/MCZ, NCC KZE/KZG, Nichicon HD, ...). Intel original boards, including later D865xxx mobos are very good.
    • Rayman
      • Dec 2006
      • 4
      My mistake these are Chocon caps that are on this board not Choyo as mentioined below.
      Rayman
      Thanks,
      Rayman
      • Rayman
        • Dec 2006
        • 4
        I am going to pick up some Intel boards then; They had better be using superior parts for the prices they charge for their boards. I will be replacing my ASUS SK8V (AMD FX-51 socket 940) system which was very reliable for the last three years I have used it; it is now showing its age. I am thinking about getting a motherboard that uses the Intel Core Duo processors. I actually robbed some caps off of a bad Intel D865 board (it had something else wrong with it other than bad caps) that was returned by a customer. I do have an unopened Intel D915GAV motherboard sitting in the closet which I never used...but it only supports the older processors. I have never used Intel boards before.. I guess it is time to try them. Thanks for the info.
        Rayman
        • qwerty99
          Xbox 1.6 Motherboards and Polymer Capacitors
          by qwerty99
          Hello!
          I need to change the capacitors on my three original Xboxes.
          Two of them are 1.6B revisions and have Hynix RAM, and the other one is a 1.6 with Samsung RAM.
          The 1.6 has the infamous Nichicon HM capacitors around the CPU, which have all bulged and started to leak. This Xbox no longer powers on.
          The 1.6B revisions have Rubycon MBZ capacitors that all look fine, but I’ll change them in due course. Both of these work fine.
          I’ve seen some excellent threads on the forum about replacing/upgrading capacitors, but I can’t...
          06-26-2022, 12:53 AM
        • Foetuss
          Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
          by Foetuss
          Hi all
          Hope this is in the correct place.
          I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
          Could use some double checking to see if I'm not doing something stupid .
          Pictures of the boards are attached.
          What I will be replacing with what : (planned)
          Soltek Golden ::
          4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
          6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
          01-18-2025, 11:44 AM
        • madscientist750
          Looking for capacitor lists for Motherboards, Video Cards, Home Appliances
          by madscientist750
          I would like to ask if there is some kind of capacitor lists for motherboards, power supplies, video cards, audio cards, microcontroller powered home appliances, and so, that i could try to find and download. I use to repair those things and i would find it helpful if i could know in advance what parts may i need for common repairs.
          07-09-2024, 09:24 AM
        • blues_spirit
          practical courses for troubleshooting pc motherboards
          by blues_spirit
          Hello from France,
          mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
          Do you think this is feasible for me? I...
          12-18-2022, 12:56 PM
        • Deby
          List of compatible laptop motherboards
          by Deby
          This is a list of compatible laptop motherboard information that I have been collecting for some time.
          And it's still ongoing.
          Every time I come across information that a board is compatible with another, I write it down.
          Anyone who wants to, can continue to expand the list.
          Packed in the rar, is an excel table that has additional information.
          Motherboards.rar...
          05-31-2024, 04:34 AM
