Hello to you guys here, I have a ABIT-WX6 Mainboard that failed to start so I had it replaced and put it in storage. I happen to come across this site I read some things there about bad caps and how to indentify them so I went and look for my abit-wx6 and inspect it I found five bad caps labeled 1000uf, 6.3 volts so I am now wondering if those caps can prevent the mainboard from starting I checked our local electronics shop here in Jamaica for replacements but they only have 1000uf, 10 volts caps (TWDC) in stock. So I am asking should I replace the caps with the 1000uf 10volts? when I do replaced them I hope the board will come back to life.
ABIT-WX6 Died can it be resurrected?
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
