Help finding identical or replacement MOSFET.
  • Alias
    • Oct 2011
    • 16
    Hey all
    I gots me an MSI P7N SLI Platinum here with a bad N-channel FET.
    IPD09N03LA N-Channel
    TO-252 package
    Infineon encapsulation
    Datasheet: http://pdf1.alldatasheet.net/datashe...D09N03LAG.html
    Pretty much anywhere I look it's obsolete and out of stock. Anyone know where I can find a suitable replacement for it? The other side there are two NIKOS P75N02LDG FETs.
    Datasheet: http://pdf1.alldatasheet.net/datashe.../P75N02LD.html
    More of a project than something that I need. If anything I can strip it for other parts or put it back on ebay as not working.
    Thanks.
    PS, I know this isn't about caps but figured someone on here knows FETs as well.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Help finding identical or replacement MOSFET.
    http://www.ebay.com/itm/120920835305
    --- begin sig file ---
    --- end sig file ---
    • Alias
      • Oct 2011
      • 16
      The 05 will work in place of an 09?
      • mockingbird
        • Dec 2008
        • 5484
        Don't buy high-powered MOSFETS from China. What they do is pay kids to extract these from old boards, and they have special machines for each package type that sands them and re-molds a thin new layer and then they print them...
        They're probably much lower spec'd than the seller claims.
        If you must buy it from there, look for an American seller. If the American seller has "American Seller" written in the product photo, it's just a Chinese re-shipper in the US shipping Chinese products.
        • Alias
          • Oct 2011
          • 16
          I dont have to get them from ebay. I think mouser and digikey have the fets he linked to, I just need to know if the 05 will replace the 09 without much issue.
          • retiredcaps
            • Apr 2010
            • 9271
            Hmm, that is odd, I could have sworn I cut and paste the part number into ebay search correctly. I don't know if the 05 is a replacement for 09.
            • Alias
              • Oct 2011
              • 16
              I was all happy until I looked at the model number. No biggie .
              • retiredcaps
                • Apr 2010
                • 9271
                I found the problem. It was a cut and paste error.
                http://www.ebay.com/itm/180896285087
                Now you probably don't need 10. I found that most ebay sellers are accomodating if you send them an email and say you want only 1 or 2.
                • DoOm86
                  Dual mosfet replacement help
                  by DoOm86
                  Hello.
                  I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                  It seems to be a 30V dual asymmetric N-channel AlphaMos.
                  Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                  And here is where I need help!
                  It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                  I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                  Thanks!...
                  10-31-2023, 12:03 PM
                • jm942
                  Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                  by jm942
                  My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                  I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                  I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                  I did voltage injection on the cpu with 0.7V and i have a current...
                  07-11-2024, 05:11 AM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
                • String2016
                  SMD MOSFET REPLACEMENT
                  by String2016
                  Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                  01-23-2025, 06:35 PM
                • String2016
                  by String2016
                  i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                  12-15-2024, 05:31 AM
