VP6 only posts with one processor after recapping...
  • Shenes
    • Jun 2004
    • 8
    I replaced all the 1000 and 1500 uF caps on my VP6 and now it won't post normally with 2 CPUs. It posts normally with 1 CPU (it doesn't matter which of the two CPUs or in which socket).
    If I reset the BIOS settings it reluctantly starts with two cpu's (after a couple of resets) but as soon as I try to save the correct setting from BIOS and restarts it refuses to post.
    I've had similar problems before recapping, always had to reset once after power up. But after that it ran normally (with the occasional system freeze once a week or soo). This was the problem i was trying to fix...
    Update: I found out it posts "reliably" with fsb's up to 115 with 2 cpu's. (The CPU's are 1000/133mHz ones)
    Any ideas of whats going on? Is it fixable?
    Thanks,
    Johannes
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    what kind of caps did you use?
    did you change the ones next to the agp?
    the 16v ones near the vrm's?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      I've had a rash if VP6's lately that ended up being unrecoverable. Many had the coil and FET's by the AGP burnt to a crisp, even after replacing them, there was still a dead short in the board which I couldn't trace out. I've 3 or 4 of these turds floating around here now. These boards are competely dead though, no POST at all.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i have 3 here like that.
        the northbridge is shot in all 3.
        1 is the one you sent.
        i will try to get chips from cheapie junk mobo's to transplant when i have time to kill.
        bga rework can be fun.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          I want PICTURES of that before and after!!!
          I got a VP6 in yesturday, the torroid coil and FET's by the AGP beyond recognition, and along with the board being destroyed, it fried a gig of Micron ECC PC133... damn shame... Melted the DIMM's... I'll post pics soon...
          Team : 49813
          Join in!!
          Team Stats
          • Shenes
            • Jun 2004
            • 8
            I ended up using Rubycon caps. I changed all 1000uF 16V, 1000uF 10V and 1500uF 10V. Had to tip over the two by the AGP.
            regards,
            johannes
            • Shenes
              • Jun 2004
              • 8
              All components look ok visually. I redid all the soldering today just to make sure that everything was soldered in properly. How much heat can the caps take from soldering, is it easy to fry them when soldering?
              regards,
              joahnnes
              • Shenes
                • Jun 2004
                • 8
                edit...
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  try another pair of cpu's if you have them.
                  sometimes bad caps damage them when the vrm's overshoot due to all the noise.
                  • Shenes
                    • Jun 2004
                    • 8
                    I don't have any spares, I hope that's not the case. They both work just fine as single CPU's though. When running dual they run stable at half speed.
                    /j
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      I had a few do exactly the same thing. I didn't test them before recapping , so I don't know if the problem was pre-existing. However, after recapping, only 1 CPU would show up.. These were a matched pair of P3 1GHz 133FSB and known good test CPU's. After scratching my head and checking the obvious things, it still did it...
                      The cure I found is this:
                      1) Remove ALL sources of power from the motherboard.
                      2) Remove the CMOS battery (IMPORTANT)
                      3) Close the clear CMOS Jumper
                      4) Let the board sit like that for a couple minutes to completely discharge
                      5) Reset CMOS jumper to normal position and reinstall the CMOS battery (actually, replacing the CMOS battery is a good idea at this time)
                      6) Reset all your BIOS settings and VOILA!! Problem solved!! Both CPU's showed up and running perfect!
                      This little procedure has worked on 4 VP6's that did this. My only explaination is that the CMOS data is getting corrupted somehow by the bad caps. The 'one CPU' problem isn't the only CMOS related glitch I've seen with this board, and completely discharging the board and the CMOS usually always fixes it.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • ugamazing
                        Procedural question about BGA rework and removal of CPUs
                        by ugamazing
                        I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                        I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                        I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                        07-12-2022, 03:11 PM
                      • proxneo
                        Recapping Sony ICF-SW55 - verifying cap values
                        by proxneo
                        Dear reader
                        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                        At the moment, I have selected replacements based on the following list of values:
                        3 x 470uF 10VDC
                        3 x 4.7uF 35VDC
                        4 x 47uF 50VDC
                        8 x 22uF 6.3 VDC
                        1 x 220uF 6.3VDC
                        5 x 100uF 6.3VDC
                        Which...
                        06-21-2023, 12:38 AM
                      • Nebukadnerzar_V
                        Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
                        by Nebukadnerzar_V
                        Hi guys!
                        I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
                        It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
                        I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
                        Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
                        Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
                        I have attached the Dump of my machine.
                        S/N: SRW2K4J
                        Reg Model: DCTR...
                        09-27-2024, 02:43 AM
                      • ducky29
                        Working with Bga chips especially CPUS
                        by ducky29
                        Hello. I mostly do small electronics and tv repairs. I am confident with small bga chips but I never was successful with removing large chips especially cpus. Is it possible to remove them just using a preheater and hot air gun or I need something more advanced like a bga machine with temperature profiles, cooling fans, etc etc.
                        Any suggestion on aliexpress/ebay are welcomed. I am on a tight budget, max I can do is about 200$. Please anyone with more experience can give me some suggestions?
                        Thanks in advance.
                        09-23-2024, 03:56 PM
                      • Windows8RTMUser
                        Repair knowledge for -55c CPU temperature on AMD Ryzen CPUs in bios, the AMD Sideband temperature sensor interface (SB-TSI)
                        by Windows8RTMUser
                        Recently I came across an x570 Aorus Elite where the temperature in bios was reporting -55c, i had checked the CPU_TEMP line connected to the IT8688
                        In my particular case, the SIC line going to the X570 chipset (PM_SIC) was shorted to ground, so far disconnecting the 0 ohm resistors connecting APU_SID and APU_SIC to the chipset has fixed my -55c issue, it seems like -55c is the fallback reading for CPU_TEMP which is just pulled up to VREF on most gigabyte motherboards
                        I wanted to post this as even the ever-reliable vlab forum was stumped on this issue
                        tags:...
                        07-28-2025, 07:26 PM
