MSI BX2 (MS-6119) - Bad caps
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Another older Slot-1 motherboard with bad Chhsi caps. This board required the replacement of 19 caps, listed as follows:
    (9) 1500uF 6.3v 10mm
    (4) 1000uF 6.3v 10mm (I used 10v replacements)
    (6) 1000uF 6.3v 8mm (I used 10v once again)
    Once again, another success story!
    BEFORE:
    AFTER:
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    by momaka
    03-12-2025, 03:42 PM
  • eryjus
    by eryjus
    05-10-2023, 11:21 AM
  • ssl6
    MSI K7T266 Pro (Ver. 1.0)
    by ssl6
    Hey Everyone,
    Long time lurker, but I think this is my first time posting.
    Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
    I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
    11-09-2023, 01:00 PM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
  • SwedishDiesel
    Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
    by SwedishDiesel
    Howdy folks,
    I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
    10-30-2021, 12:47 AM
