Gigabyte 8IRXP start itself!!!!
  • LinPack
    • Sep 2006
    Hi mates
    My computer with a P4 1.6Ghz and GA 8IRXP mainboard suddenly died. When I plug the power cord in, it starts itself.
    I removed all the expansion card, ram, even CPU, the mainboard keeps start itself again everytime i plug it into main. But it not boot, here's the symtoms:
    1. Power on every time plug power on.
    2. Not boot, no POST, no beeep, no video, justpower on.
    3. All the power rails are ok, measured by VOM multimeter
    4. VCore OK, 1.5 volt, measured at the VSEN of Intersil HIP 6302 VRM controller.
    5. CPU not warmer when power on
    7. When i remove the CPU, VCore no longer available, return to 0 Volt (Is it normal?)
    8. It's a dual bios board, so dead bios is rare
    9. All caps are visually checked OK, but i haven't replaced. Measured caps onboard, there's no short circuit, but dont know if caps are leaked
    What i have done:
    1. Replace the CPU
    2. Replace PSU
    3. Replace RAM
    4. Remove and repalce everything else
    5. Clear CMOS 1001 times
    Still no lucks.
    Please advise me what to do next, should i re-caps all or should i do some more check? I really dont know what to check next.
    And the 2 bios chips are soldered, too bad!
  • Tom41
    • Oct 2005
    • 338
    • England
    Re: Gigabyte 8IRXP start itself!!!!
    Many boards do have an option to restart automatically after a power outage - when the mains is re-applied, the system starts up without you having to press the Power button.
    Does it power off if you press and hold the Power button on the front? Check if the Reset switch (if applicable) is jammed in or connected the wrong way round. Also try a different video card - many boards refuse to boot if no video card is inserted, and the video card itself may be dead.
    What make are the caps? Some brands such as Teapo tend to fail without any physical signs - to be sure you'd need to desolder the caps and check with an ESR meter.
    You know there's something wrong when you open your PC and it has vented Rubycons...
    • LinPack
      • Sep 2006
      No, the power switch has no effect. I've tripped everything out, even the CPU was detached. It's just the mainboard only and it power on itself, even without the CPU.
      As I said, I've changed the whole system and it's the mainboard fault, 99.99% definitely.
      I think i should re-cap it.
      But i want to listen to your advise before i do that.
      • Rainbow
        • Aug 2005
        • 1375
        Does the CPU, chipset and clock generator chip get warm? If not, then it might be a bad crystal.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
          03-31-2024, 02:12 PM
        • noinimod
          Sony 55X900E no standby light, no power. Replaced mainboard already
          by noinimod
          No standby red light, nothing
          This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
          Disconnected JK3 power board from main board, checked voltages on all the pin outs
          At a few pins I can see the power supply providing 19.5V to the main board
          Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
          LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
          12-22-2021, 12:58 AM
        • Jembang
          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
          by Jembang
          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
          11-01-2024, 09:55 AM
        • stylishconsultant
          un60j620dafxza - Samsung No Display Problem
          by stylishconsultant
          Hi All,
          Need help.
          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
          09-04-2024, 03:26 AM
