Need L1117 voltage regulator for Intel D865GVDS (Dell) mother board
  • everell
    • Jan 2009
    • 1514
    I have a dead, dead, very dead motherboard from a Dell computer. It is an Intel D865GVDS. It had an extremely hot voltage regulator feeding the BIOS area, obviously bad. Other L1117 voltage regulators on this board not running hot. Problem is that I can't find a replacement part. Info I have found indicate that this is a variable voltage regulator. All of the L1117 series regulators I can find are fixed voltage.
    So....any information or help (other than trash it) would be helpful.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
  • jetadm123
    • 2169
    Re: Need L1117 voltage regulator for Intel D865GVDS (Dell) mother board
    Maybe what you're looking for?
    http://www.digikey.com/scripts/dksea...=0&ptm=0&fid=0
    • LDSisHere
      • May 2012
      • 727
      • U.S.A.
      Are you sure the voltage regulator is bad or is the problem? If you are getting the correct voltage out it may be another part that is bad or shorted that is overloading the problem regulator. Of course you may need to try another one to check this, which puts you back at square one of needing a new one.
      • everell
        • Jan 2009
        • 1514
        Hot as it was, I am sure the chip is a goner....as to what else may be wrong.....don't know yet. But thanks Jetadmin - you have pointed me in the right direction.
          master hoarder
          • May 2008
          • 12176
          Remove regulator from the board and test it with a load. Also check resistance on the pads on the board where the regulator was to see if perhaps some other component is shorted. SMD multi-layer ceramic capacitors LOVE to go short circuit.
          If you determine the regulator is bad, let me know. I have a few 1117 regulators from various boards. Not sure if any are adjustable, but I can check. Can ship you one in a mail envelope easily.
          • everell
            • Jan 2009
            • 1514
            Thanks momaka, but I have already ordered from Digikey - all of 63 cents plus a little first class postage. I have lost the chip which I took off the board, but will be checking the other components around it very carefully.
              ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
              3+1 Voltage Regulator for IMVP-7/VR12 CPUs
              Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
              core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
              configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
              serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
              Based on Intersil's Robust Ripple Regulator...
              11-05-2024, 03:24 PM
            • playit
              diy - voltage injection possiblity with voltage and ampere regulator - possiblity ?
              by playit
              hello ,for diy voltage injector for short killer/finder -- is it possible to use something like this - LM317 DC Linear Regulator, DC-DC 4.5~40V Turn 1.2~37V, Step Down Power Module, Adjustable
              and ampere controller along (to make it zero amps ) with some addons(transistors diodes etc.) for it -- and use some 5v adaptor or 3.3v volt rail of my smps power supply as input and finally get 1v and zero amps for injecting voltage to find out short circuit component ? ..
              for source input -- can we use 3.3 -4 volt 18550 battery ?( i have some of those ) and then adding ampere regulator...
              02-26-2025, 05:39 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • artvandalai
              Help identifying voltage regulator on this concept 2 pm5 monitor pcb board?
              by artvandalai
              This Concept 2 rower pm5 monitor doesn't shut down. It keeps turning on and stays on after being turned off. I read on another forum by another user that replaced the same component to check the voltage regulator.
              The monitor should pull around 35mA when turned on and in shutdown it should drops to around 0.060mA. Any advice on finding the voltage regulator on this board to check if it needs to be replaced?
              11-05-2024, 07:38 AM
            • shakib200
              Ram regulator misbehaving DDR3 VTT voltage Tps 51216
              by shakib200
              The ram regulator produces VTT voltage of 0.65V and the display comes. When we restart the laptop the VTT voltage becomes 0.75 and no display.[Used same ddr3l ram].
              Also, it becomes 1.35 V on the ram coil and all are okay but after restarting Voltage becomes 1.5V with no display.
              03-16-2024, 11:33 AM
