Foxconn C51XEM2AA with Teapo caps
  • Super Nade
    • Jun 2006
    • 294
    I don't own the board, but you can find pretty detailed pics in the following thread:-
    http://www.xtremesystems.org/forums/...d.php?t=103808
    Q6700 @ 3.6 GHz
    Zippy GSM-6600P
    Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
    Abit IP35Pro
    ATi HD4870
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Foxconn C51XEM2AA with Teapo caps
    only little ones. i would be more concerned about that bunch of light green ones near the sata connectors, they look like Lelon (havent seen them for a long time)
    the rest of the caps are fine - rubycon mcz, fujitsu fpcap and chemicon
    • Super Nade
      • Jun 2006
      • 294
      Well, if that's the case, DFI are claiming that they use 100% Japanese caps (probably Nichion), so I'm going to put DFI on my list of Conroe boards, along with ASUS.
      Is this correct?
      Rubycons are the ones with the gold stripe.
      Yellow are Chemicons
      Green ones are Lelon
      Teapo's are clearly visible.
      Which ones are Fujitsu?
      Q6700 @ 3.6 GHz
      Zippy GSM-6600P
      Abit IP35Pro
      ATi HD4870
      • Rainbow
        • Aug 2005
        • 1371
        The yellow ones are Fujitsu.
        Lelon
        • Super Nade
          • Jun 2006
          • 294
          That bad eh?
          If the capacitor layout is broken down location-wise, do you predict VCore or VDIMM drooping? If you were a board manufacturer, how would you priorotize capacitor placement?
          Q6700 @ 3.6 GHz
          Zippy GSM-6600P
          Abit IP35Pro
          ATi HD4870
          • Rainbow
            • Aug 2005
            • 1371
            Lelon "quality" is comparable to GSC and Chhsi.
              by momaka
              03-12-2025, 03:42 PM
              by momaka
              03-15-2023, 10:17 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
