Abit BP6 Leaking and Bulging Caps
  • TheSolarShed
    • Apr 2012
    • 19
    • South Africa
    One or more of the labs at my university threw out discontinued equipment, and amongst the pile was this Abit BP6. Got it home and spotted the problem caps straight away.
    I started to desolder some of these pathetic Tayeh caps and this is what the worst one looks like underneath. The rest are just bulging slightly.
    I've read the Abit BP6 recapping thread posted by Topcat and want to replace the caps with these modded values. What rated rippled current and ESR value must I look for? Or will any good-quality low ESR cap with specified capacitance and voltage be fine?
    I've only looked at Rubycon from one local source so far and this is what I've found for 2200uF (both 10mm):
    -ZLH series, 6.3v, 1960mA ripple, 0.020Ω ESR
    -ZL series, 6.3v, 2150mA ripple, 0.022Ω ESR
    My first multi-processor computer, and it came from the dumpster . I hope it works after the recapping.
    Regards,
    TheSolarShed
    Project CapRep
    Good cap replacement finder
    2354 caps in database so far
  • re-atari
    Denon AVR-X2000 mainboard caps bulging
    by re-atari
    I have been using a Denon AVR-X2000 receiver in my living room for several years now, works perfectly, am very pleased with it. Recently I acquired another one, advertised as defective with flashing red led a few seconds after switching on. Picked it up to try repair and use in hobby room. After switching on, the on/off indicator led indeed initially flashes green for about 2 seconds, during which the display is visible, and then starts flashing red (at 2Hz) with a switched off display.
    I'm afraid the service manual is too large to upload here (55Mb), it can be found at https:/...
    09-23-2020, 10:37 AM
  • ziplock
    Abit BE6-II motherboard
    by ziplock
    Greetings,
    I have an Abit BE6-II motherboard that posts sporadically with the bare minimum components installed - CPU, RAM, PSU, and a Keyboard. I know it posts when the speaker beeps. Re-seating the components has no effect.
    I thought the sporadic posting might be capacitor related. Upon inspection, non of the caps are bulged or leaking and they are all original. So, I pulled them ALL. While the ESR is OK, over half of them are leaking current between 1 and 2 mA. The biggest offenders are way out of spec, like a 1500uf / 6.3V measuring 2600uF and many of the 820uF caps...
    04-20-2025, 02:09 PM
  • Paxman_Swede
    by Paxman_Swede
    Hello!
    01-14-2025, 09:51 AM
    by momaka
    03-15-2023, 10:17 PM
  • Blag
    Japanese 3DO with leaking caps - (nearly) full poly replacement
    by Blag
    Hi all, I've got a 1994 Japanese Panasonic 3DO with 2 leaking caps. Since all the caps are now 25 years old I decided to swap them all before more of them start to leak.
    To reduce the danger of another leakage in the future I decided to swap every possible cap with a poly cap.
    Has anyone here done that already and give me some hints?
    I found a "fitting" (voltage, uF and measurements) poly cap for all but 3 caps. The largest cap is a 6800 uF 25v cap, since there aren't any 6800er polys I'll get a high quality electrolyte one with a higher temp rating. The...
    10-26-2019, 07:59 PM
