Need help finding tiny 200V caps.
  • LLLlllou
    • May 2011
    • 201
    So I acquired a Netgear WPN824 which was flaky as all hell. Recapped it and it's adapter, and it works fine now.
    I replaced an off brand (can't remember what it was) 470uF 16 volt output cap in the adapter with a Nichicon HM 1000uF 16V, which has caused the adapter to only buzz when it's not plugged into the router (before it was buzzing all the time.)
    I want to replace the HV input capacitors (just for the hell of it, they both test fine) but can't find anything on Digikey's website that'll fit.
    I need:
    22uf (or more) 200V cap. of no more than 10mm X 18mm
    5.6uF (or more) 200V cap of no more than 8mm X 18mm
    Original caps are:
    Aishi 22uF CD11GF series (240ma ripple at 100KHz, 132ma 120Hz) and
    Aishi 5.6uF CD11GH series (cant find info for 5.6uf, but 4.7uf in same size case is rated 110ma at 100KHZ and 60.5ma at 120Hz)
    They were apparently designed for use in florescent ballasts.
    Any one know where I can get small high quality 200V electrolytics with equal or better specs?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: Need help finding tiny 200V caps.
    Are they those short stumpy ones?
    • LLLlllou
      • May 2011
      • 201
      Not particularly short or stubby, and I can go up to 18mm.
      • mariushm
        • May 2011
        • 3799
        Farnell has them in stock...
        http://uk.farnell.com/nichicon/uvy2d...ial/dp/1899800 10uf , 8 x 11.5, nichicon
        http://uk.farnell.com/vishay-bc-comp...00v/dp/1165454 22uf 10x16, vishay
        Not much chance of finding lots of caps in those sizes
        • LLLlllou
          • May 2011
          • 201
          I'm in the US, so shipping would be retarded.
          Damn shame there's no more room.
          • mariushm
            • May 2011
            • 3799
            The US version of farnell is newark.com :
            http://www.newark.com/nichicon/uvy2d...lar%20Products
            http://www.newark.com/vishay-bc-comp...MAL215262229E3
            I could buy them from you when I buy other things for me from Farnell and mail them to you and it would cost you about 3$ in shipping and about 1 - 2 weeks of your life.
            Well, I could buy the Vishay one, as the Nichicon one is only in the US warehouse and they want about 40$ (~15uk pounds) to ship them to me across the ocean.
            On the other hand, as you can see above, it would cost you "only" 20$ to have the Vishay ones sent from UK to you in US.
            So at least you could get the Nichicon ones with minimum shipping fees.
            • LLLlllou
              • May 2011
              • 201
              It's not worth it, as I said they test OK, I just like having better caps in everything. If I could find a source of both for less than a buck in quantities of 10, I'd get them.
              BTW, never knew Farnell was Newark, ya learn something everyday.
              • chth96
                Is it possible bridging tiny broken trace
                by chth96
                When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                cutting tiny trace.
                This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                12-03-2022, 11:32 PM
                LENOVO ThinkCentre M72e Tiny ThinkCentre M G465 Specification for Upgrade or Repair
                This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-12-2024, 03:36 PM
                LENOVO ThinkCentre M72e Tiny ThinkCentre M G470 Specification for Upgrade or Repair
