Gigabyte GA-6VTXD - no power?
Re: Gigabyte GA-6VTXD - no power?
The seller refunded my money and let me keep the board as well.
So now I have basically "eternity" to determine what might be wrong with it.
In the meantime, I will probably put the Tualatins into an Acorp S815ED (which needs to be recapped...GSC crap caps that are visibily swollen).
Thanks for all of the help from everyone thus far, and the saga continues.
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by pete61Hi all I have got a gigabyte 4080 super gaming oc with a resistor and three caps missing, Can anybody please tell me what the values for these are, See pic for details, Thanks in advance....
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
- Loading...
