Radeon x1600 Pro Vcore? (polymod intent)
  • Khron
    • Sep 2006
    • 1350
    • Finland
    I got my grubby mits on a busted Club3D Radeon x1600 Pro video card on monday, and i only got around to it today.
    One vented Sacon FZ at one buck converter on one corner of the board, and an apparent drain-to-source short on one of the FETs of the other buck, at the other end of the board. the latter had two 1000u/16v FZ's after it.
    I proceeded to unsolder all four fets, and replaced them with slightly higher current-rated ones (off a junked mainboard). Now, just before replacing the fets, i measured again on the pads - the short was still there I took of that pair of FZ's and sure enough, short's gone.
    Now, i don't have any caps in my stocks that are as short as the originals, but... Would poly's rated for 4v be enough? I've got some Chemicon poly's and some Oscon's.
    Surely the GPU's Vcore can't be higher than 2v... Right?
    Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
  • Old Thrashbarg
    • Jan 2010
    • 20
    Re: Radeon x1600 Pro Vcore? (polymod intent)
    As long as the caps are actually on the output side, then yes, 4V caps should be fine. The GPU voltage on a stock x1600 is somewhere in the range of 1.5V I believe.
    However, you said you measured pads for a short, that would indicate that you have a multimeter, meaning that you can measure voltage too. That's the best way to be sure, just plug in the card and power it up, see what sort of reading you get across the legs of the caps (or rather, across where the caps were). It won't boot properly with the caps removed, but you'll still have the voltage there.
    • b700029
      Banned
      • Sep 2010
      • 640
      16v seems more like it's the input side (12v). As above poster said, better to check.
      • Khron
        • Sep 2006
        • 1350
        • Finland
        On the input side, both buck converters have a Sanyo 470u/16v. The FZ's i removed had their + leg connected to the source/drain connection of the upper/lower FET, so i'm quite positive they're on the output side
          AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
          The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
          10-01-2024, 12:46 PM
          AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
          The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
          10-01-2024, 01:07 PM
          AMD Radeon RX 470 / RX 580 Schematic & Board View
          The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
          10-01-2024, 12:52 PM
          AMD Radeon R7 340 / R7 430 Schematic & Board View
          The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
          10-01-2024, 12:36 PM
          AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
          The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
          10-01-2024, 12:20 PM
