8800gt with a bad capacitor.
  • erhat
    • Aug 2011
    I have what appears to be a bad capacitor on the graphics card. Looks like a piece of rubber (atleast I think it's rubber) that blew through the bottom. I hope you can see it more clearly on the pic.
    http://www.pohrani.com/f/2s/80/4YCcE9kD/p8120061.jpg
    From what i've read that particular capacitor isn't crucial.
    "The one and only generic electrolytic capacitor! We found this lone ranger cleaning up the 12V supply where other manufacturers would have left a blank spot."
    http://vr-zone.com/articles/-xpertvi...gt/5468-2.html
    So my question, is it safe to simply leave the cap there or should I remove it ?
    Thanks.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: 8800gt with a bad capacitor.
    If it blew it means it was doing something. Without it, the card may get unstable in some situations. I would replace it with a better quality cap.
    A working TV? How boring!
    • Evil Lurker
      Warranty Voider
      • Feb 2011
      • 454
      The only remaining question is who made the thing and its series. If we knew that, the parametrics of the capacitor can be obtained from its datasheet and a suitable high quality non-generic japanese manufactured capacitor installed in it's place. 220uf @16v is a dead common value, should be easy to locate.
      • erhat
        • Aug 2011
        Besides the capacitance and voltage all I can read from it is that it's manufactured by Rifeking, it says it's low ESR and that it's rated at 105 C.
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • vionescu
          Zotac 1070 mini blew off a capacitor
          by vionescu
          Hi, last night my zotac 1070 mini blew off a capacitor. I've had a look and identified it to be C336 capacitor and maybe the R005 resistor. Does anyone have any idea what kind of replacement capacitor I need to get to fix it or any boardview schematics for the card?...
          03-19-2022, 01:09 PM
        • shanedev93
          Spot welder capacitor blew up
          by shanedev93
          Spot welder capacitor blew up should just replacing them fix it? The board is very dirty gonna remove it and clean it an see if I notice anything wrong that could cause this issue.
          Video of the smoke show
          https://youtube.com/shorts/AFJgRbsHGhs?feature=share
          06-21-2023, 01:02 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
