Gigabyte 7VAX repair
  • Fatal0E
    • Jan 2004
    • 252
    I have a gigabyte 7vax that was in use for just over a year.
    It had 4 1500uf 6.3v GSC capacitors around the cpu socket, 2 of these bubbled and leaked. The system was completely unstable, blue screening and rebooting constantly.
    It has been replaced so I just wanted to play around with it after reading a bit about replacing caps.
    I dug out my trusty soldering wand, (just a plug in always on cheapy with a huge tip!), and pulled out a dead MSI board with failed capacitors around the dimm slots. It had 5 Nichicon 4700uf 6.3v capacitors, these were silver aluminum looking, no color at all and fairly large, I removed these and noticed they would not fit in one location do to size contraints. So I found a dead intel board i dug out of a dell. It had 3 Rubycon 3300uf 6.3v capacitors that I could put to use.
    I removed all 4 GSC caps from my play board, only 2 of which were bad, but figured what the hell, might as well try it right the first time.
    I installed 2 Rubycon 3300uf 6.3v caps in the location right behind the printer port, fit perfect. I installed the remaining Rubycon at the other location, then for the 4th cap at the second location i used one of the big 4700uf Nichicons.
    Setup board with a 700 duron (no biggy if i fried it), installed winxp, ran prime 95 for about 30 min, worked great.
    Pulled out a AIUHB 2100+, installed, ran prime 95 for 2 hours, worked great. Turned up the front side bus to 166, nice overclock, ran prime95 for about 6 hours this afternoon, worked perfect.
    So board seems to work well so far, but after reading up some more, wonder how bad it is that I replaced the 4 1500uf caps with 3 3300uf's and a 4700uf? This cause problems in future?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    if the converter can start against the discharged caps without hitting overcurrent shutdown then ok.
    just means cleaner power.
    • DynaxSC
      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
      by DynaxSC
      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
      General test conditions:
      - Tested with Core i5 6500 and Core I7 6700K - no difference
      - Default BIOS settings, but tried also altering several memory setting - does not change anything
      What is wrong:
      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
      03-21-2025, 06:23 PM
      Thermal pad thickness for various laptop GPU / Graphics Cards
      ASUS Dual RTX 2070 OC 8GB
      ASUS ROG STRIX RTX 3080 OC
      ASUS ROG STRIX RTX 3090
      ASUS TUF Gaming RTX 3080 OC Edition
      ASUS TUF GTX 1660 S-O6G GAMING
      EVGA RTX 3060 Ti XC GAMING 8GB
      EVGA RTX 3060 XC GAMING 12GB GDDR6
      EVGA RTX 3080 FTW3 ULTRA GAMING
      EVGA RTX 3080 TI FTW3 ULTRA GAMING
      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
      Gainward RTX 2080 Phoenix GS Specs
      Gainward RTX 3070 Phoenix 8GB
      Gainward RTX 3080 Ti Phoenix
      GIGABYTE AORUS RTX 3080 MASTER 10G
      02-09-2024, 08:08 AM
      A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
      by momaka
      More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
      And a shot of the label:...
      01-26-2022, 03:26 AM
      Gigabyte G series G5 MF-5 Notebook Specification for Upgrade or Repair
      This specification for the Gigabyte G series G5 MF-5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the G5 MF-5 boardview and G5 MF-5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte...
      09-07-2024, 07:19 AM
      Gigabyte AORUS 15X Netbook Specification for Upgrade or Repair
      This specification for the Gigabyte AORUS 15X Netbook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15X boardview and 15X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte AORUS 15X Netbook...
