SuperMicro 370DLI bad caps?
  • pantoine
    • Feb 2006
    I have an SM 370DLI board I got off eBay which has been unstable since I bought it. The board was manufactured in week 1 2001... and didn't look used when I received it.
    I improved stability greatly by replacing the caps around the DIMM slots with decent low ESR caps even though the caps I replaced had no bulges etc. The unit is now stable in the short term (POSTs/boots), but is still unstable on extended running and particularly with disk activity.
    All of the caps were Sanyo's, which folks generally regard as excellent, so it surprised me when I got more stability when I replaced the caps around the DIMM slots.
    Just wondering if it's worth replacing more caps? Would you start at the VRM or the remainder of the board? Anyone seen a problem like this with all Sanyo caps, no bulging/wear and yet bad??
    Thanks in advance,
    Paul
  • MD Willington
    • Sep 2004
    • 702
    Re: SuperMicro 370DLI bad caps?
    Probably would not hurt, even though they are a good brand, nothing lasts forever...
    MD
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
    • Foetuss
      Gigabyte GA-6OXT :: caps question
      by Foetuss
      Good evening
      I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
      Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
      But I was also suprised about the bigger boys, which are 330µF 25V.
      Could it be they used 25V caps because they were cheaper / available at that time?...
      02-11-2025, 12:22 PM
