AOpen MX3S-T capacitor disaster! :-(
  • peterpan783
    • Jan 2004
    :cry:
    Hi. this board has around 11 blown capacitors.
    Any ideas of what brands should I get for the replacements.
    What's the average price for each?
    I know that capacitor failure is inevitable, but I'd like to postpone it as much as possible.
    Heard from repairpeople that the original capacitors sucked!
    Most MX3S-Ts die that way.
    Any suggestions to revive the dead?
    Thanks!
    Posted by Peter Pan :-)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    I tend to use Nichicon, Sanyo, Panasonic, Mallory, and Rubycon low-esr replacement caps. I've never had a repeat failure using these brands. I have not seen many Aopen's with bad caps, maybe 10 or 15 or so... I would replace everything 680uF and up on your board. I have seen capacitor values less than 680uF fail, but not very often. (330uF 'Choyo' brand on Gigabyte's were common ones on several boards).
    Cost of replacement caps depends on where you buy... Digikey is rather expensive if buying small quantities, as are most vendors... Some vendors won't even talk to you if you don't plan on ordering 1000 caps or more...
    if you need some caps, shoot me an email with what values you need and how many...
    TC
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • peterpan783
      • Jan 2004
      Hello Topcat,
      He he, this is going to be funny. I hope you're still active in the forum.
      I had that problem with an AOpen MX3S-T. Took it to a friend who knew what he was doing, replaced all the capacitors and the MB ended up even better than it was when new!
      It's over a year now, I'm in a different country, and this time I was looking for information again on repairing motherboards (and eventually found my own posting in this forum, which I had forgotten). In 2004 I was desperate to have mine fixed. This time, I am a system builder with a few completely dead MBs which I'd like to put back to use. I would like to do the repairs myself. As they are dead anyway, I've got not much to lose in experimenting and learning how to do it.
      Most are AMD Socket A, which are not so obsolete.
      As I said before, they have problems that lead me to suspect of failing capacitors.
      Most of them won't power up. Completely dead.
      I have a couple who start up, I can get to the BIOS, etc, but refuse to boot from floppy (BIOS set to boot from floppy first). I've tried different cables, and different floppy drives (which are known to be Ok) but keep getting the same problem.
      Got another one. When powered up, it does not give any video, and makes the keyboard LEDs blink constantly.
      Another one, the two capacitors next to the ATX power connector got really hot and smoke was coming out. Turned it off immediately. the rest of the capacitors seemed to be Ok (were cold).
      Am I right in my suspicions?
      I am in England at the moment. How much would it cost me a few repair kits.
      I could send you the exact model numbers (even photographs).
      Cheers!
      please reply to: peterpan783ebay@yahoo.es
      • MORETTIGIAN
        by MORETTIGIAN
        Title:
        Description:
        Procedure performed:
        - Removed backplate
        - Reapplied thermal compound
        - Reassembled card
        09-18-2025, 12:14 PM
      • Prolog
        by Prolog
        12-01-2024, 08:27 PM
      • Agent24
        Dick Smith Q-1760 linear power supply filter capacitor question
        by Agent24
        I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
        It has at least one problem.
        The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
        I have already ordered a replacement potentiometer, so that's not an issue.
        Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
        All are CapXon...
        10-21-2025, 05:39 PM
      • chth96
        by chth96
        12-22-2023, 04:34 AM
      • chth96
        by chth96
        06-02-2024, 07:31 PM
