Re: Soyo KT333 Dragon Ultra Platinum
Nice work, Happy to see it get new life. I always did like the looks of that board.
So here is the Board I bought from Brethin, completely recapped. I removed every single SACON and replaced them as follows:
Location UF V Size Brand
ELC9,10,11,12,13,14,15,16,17 3300 6,.3 10x25 Panny FJ
ELC1,2,3,4,5 1500 16 10x20 Ruby MBZ
ELC8,19,25,26,29 1000 10 8x15 Nichi HM
ELC30,31,CE2+?(group of 4) 1000 10 8x20 Panny FM
CE3,CE1,ELC34,ELC24,ELC20 1000 10 8x20 Panny FM
ELC17,ELC18 1000 10 8x15 Nichi HM
ATX Plug(x2),, EC21 470 16 8x11.5 Nichi HN
EC39,40,34,30,35,17,top of IDE 220 16 5x11 Panny FR
EC41,front AGP,EC45.EC32,EC24,EC20 100 16 5x11 Nichi PW
EC5,7,12-14,16,22,23,26,28,42-44,top IDE 22 25 5x11 Nichi PW
EC1,ATX plug(2),EC4,6,15,16 10 25 5x11 Nichi PY
I recapped two of these boards last week, both working. the non-brethin board had many bulgy caps.
I knew something wasn't right I just couldn't figure out what without roasting ya..
Your name is Pyro after all. I figure you can handle heat..
A Soltek with an AFU BIOS I can believe.
*facepalm*
Soltek, not Soyo
>No, it sounds like he knocked the plug loose.
Nah. Other ports failed the same.
Oh, I see it now.
Failed to detect the USB keyboard once huh.
Yup that's some problem all right, all Soyo's fault obviously.
Can't see how you had an nforce2 on a Soyo though....
nForce2 came out July 2002.
Soyo's "All mobos' list included discontinued boards at least back to Socket 7.
Here's 'All mobos' list for Dec 2002.
http://replay.web.archive.org/200212...cts/select.php
- No nVidia chipsets at all.
Here's 'All mobos' list for Aug 2003.
http://replay.web.archive.org/200308...cts/select.php
Here's 'All mobos' list for Dec 2004
http://replay.web.archive.org/200412...cts/select.php
- One nVidia chipset. An nForce3.
- That does not support Barton.
http://replay.web.archive.org/200412...desc.php?id=16
Checking Nov 2006 shows no new/other Soyo + nVidia boards.
Interesting that you had an nForce2 on a Soyo when Soyo never used that chipset.
Also interesting that you used a Barton on a Soyo nForce board when they never made an nForce board that supports Barton.
Geriatric moment?
Bios did not recognise USB keyboard despite being successfully detected with everyday use in the past few months.
Disable, save and exit and reenable, cured the problem.
That was pretty vague.
So describe the problem then.
Where did I say the problem manifested itself in OS ? It was in pre-boot environment and had absolutely nothing to do with any os.
Neither addresses the issue which is on Bios and not on the driver level.
Originally posted by Pyr0Beast View PostHmm ? Other nforce2 boards and even nforce1 never had a similar issue.
http://arstechnica.com/civis/viewtopic.php?f=8&t=670244
http://www.computing.net/answers/har...ont/21868.html
http://www.msfn.org/board/topic/1224...s-for-nforce2/
http://www.hardwareanalysis.com/content/topic/11829/
That's why nVidia released this driver for "General compatibility fixes".
http://www.nvidia.com/object/nforce_udp_winxp_5.10.html
Please note: Release date on that driver was: September 17, 2004
It came out AFTER XP SP2 and so obviously was not included in SP2.
.Last edited by PCBONEZ; 05-12-2011, 09:42 AM.
No, the cap is fine. Other USB ports (front and bracket) didn't work as well. It was completely a software issue, like something locked machine up and couldn't read USB.
did you change the cap filter going right to the USB port?
Is not a "Soyo issue" then.
Just happens to be on a Soyo.
I think integrated nForce2 USB and Xp
Last time it failed to detect USB keyboard - had to disable then reenable USB keyboard support with PS/2 keyboard.
Otherwise, it runs perfectly smooth with barton@2GHz@1.5V (passive cooling)
What is the USB chip and what OS?
The soyo socket A board which I have (and have successfully recapped) - bios has certain isues with USB devices.
