Bad tocon cap, iogear kvm. Brand to replace, where to buy online?
  • danmcgrathm
    • Feb 2006
    My iogear kvm blew a tocon cap. 100uF, 16v, radial. I'm looking to replace all 8 of the caps on the board - any advice as to brand I should buy and where I might buy them online? I live in Wisconsin USA. Thank you!
    I'll post a pic of the blown cap for fun in the near future : )
  • Newbie2
    • Sep 2005
    • 885
    Re: Bad tocon cap, iogear kvm. Brand to replace, where to buy online?
    The USA has many vendors you can get caps from. You can buy some from the Badcaps forum admin (Topcat) or you can purchase caps from Digikey USA or Mouser.
    100uf caps don't fail very often (very rarely) but P11198-ND on Digikey is a great replacement for the failed Tocon 100uf 16V capacitors.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      what model kvm?
      Ludicrous gibs!
      • danmcgrathm
        • Feb 2006
        The KVM is an iogear miniview ultra 8-port, ps/2, rack-mount. And thanks for the advice! I had been looking at the digikey site but was unsure as to which 100uf I ought to purchase. I'll check out mouser as well for comparison shopping. I wonder how much Topcat would charge - it would be cool to support the cause : ) Thanks again!
        • Newbie2
          • Sep 2005
          • 885
          Topcat usually has caps that are 1000uf and higher, since he's mainly in the motherboard recapping section. For 100uf caps I guess he wouldn't be happy with supplying them. Mouser is also a good source for Americans. Look for cap brands such as Nichicon, Panasonic, or United Chemi-Con.
          My gaming PC:
          • danmcgrathm
            • Feb 2006
            Thanks for the tip Newbie2. I was wondering about Topcat because after checking out the site, it did indeed seem that the caps (and kits) are focused on mainboards. I just placed my order with digikey for the part number you mentioned - Panasonic. I'll post the results once I've finished replacing the caps. Also the pic - the cap blew nicely, the cap of the cap (ha!) totally flew off and was rolling around inside the case : )
            • Stanley1843
              BEST 505 Vs Mechanic Brand Reballing Balls with Lead
              by Stanley1843
              has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
              06-22-2024, 11:06 AM
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
              Meanwell Switching power supplies intermittent every capacitor under 100uf
              Here is the eBay website link where I bought them from
              https://www.ebay.com/itm/276135936202
              I have been waiting for these switching power supplies to come well they came in today so I took one apart and found that it Capcon and EIite and another brand that is on my list of capacitors to replace on site it has several 0.47uf @ 50 volts ESR value twice the reading of a new one 10 UF @ 50 volts almost twice the ESR value of a new one 47 UF @ 59 volts with double the ESR value 100 UF almost the same as a new one it got replaced for good measure Iit was a brand if I see them...
              11-25-2023, 06:05 PM
              HP Pavilion 15-cx0198tx Notebook 15 Specification for Upgrade or Repair
              This specification for the HP Pavilion 15-cx0198tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-cx0198tx boardview and 15-cx0198tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
              09-06-2024, 09:17 AM
              HP Spectre x360 13-ae511tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
              This specification for the HP Spectre x360 13-ae511tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-ae511tu boardview and 13-ae511tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 06:27 AM
