A8AE-LE or AmberineM-GL6E motherboard
  • bjunk10
    • Feb 2011
    Recapping motherboard and lost track of where the 470 uF cap is located. If anyone has one of these laying around I would greatly appreciate it if you could tell me its location. Thanks. bill
  • Docus
    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
    by Docus
    Hi everyone 😀,
    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
    1. I already own the exact same model, but its plastic chassis is badly damaged.
    06-10-2025, 04:24 PM
  • Archimedes
    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
    by Archimedes
    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
    Fans are spinning. Blindly could install windows11 and got the device manager...
    07-30-2024, 05:14 PM
  • dragon3x
    by dragon3x
    power on.
    Here are some examples :
    switching supply area).
    than 6.3 V.)
    03-21-2025, 02:46 PM
    ASUS P5GC-MX motherboard recap
    by momaka
    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
    So here is what the motherboard looked like with its original caps:
    CPU VRM area up close…...
    01-27-2021, 11:59 PM
  • dhenion
    Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
    by dhenion
    I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
    The original board was:
    ASUS X510UNR REV 3.0 A
    The replacement board is:
    ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
    It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
    01-30-2024, 01:45 PM
