Biostar MCp6p M2+
  • Mysteriphys
    • Dec 2010
    Biostar MCp6p M2+
    Hi, new here, amateur Electro Geek.
    I got this machine from my mother after my last one fried, I actually specced it out for her to be relatively similar in capability. the problem I'm having that's got me here at the moment is it's reading a tad off in Everest, mostly I'm just wondering if maybe it's normal, but if it's not then I'll likely get to work fixing it asap.
    Voltage Values
    CPU Core 1.33 V
    +2.5 V 1.20 V <------ This troubles me...
    +3.3 V 3.36 V
    +5 V 5.05 V
    +12 V 12.10 V
    +5 V Standby 4.92 V
    VBAT Battery 3.07 V
    I looked over the normal electrolytic caps and they all seem fine, but it has the low profile metal covered deals, they all say 2.5v so I thought maybe they're the issue?
    but i'm not touching anything until i know if it's a problem! thanks for any feedback!
  • brethin
    • Dec 2008
    • 1907
    Re: Biostar MCp6p M2+
    Without knowing more detailed information my guess is you misread it.
    My guess is that line should read +1.5 V 1.20 V which would be normal.
    • Mysteriphys
      • Dec 2010
      I dunno there, I've had a few diff pc's that I've run everest on and they always read 2.4ish, I've been trying to get more info on the board but I can't find anything definitive. which is why i came here, I figured people here would have a bit more experience with different boards like this.
      I'll try to find more info, thanks anyway
      Just checked the bios, it's the chipset voltage reading, as a side note though, the system locks up when i'm in the bios now O.o I don't overclock or anything, kinda wierd imo. but probly not a cap related issue, since I'm using the machine right now in xp no issues.
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        whats your cpu temp running at?
        I've seen cpu's run hotter in the bios then in windows
        i've purchased this board for many people before with no issues, but that means squat
        • Instafixx
          Macbook A2179 820-01958
          by Instafixx
          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
          I checked the Power Sequences below and found this -
          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
          05-20-2023, 05:19 AM
        • cook
          HP Power Supply 6632A: Fast Mode vs Normal Mode?
          by cook
          FAST MODE vs NORMAL MODE
          I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
          I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
          06-07-2020, 05:32 AM
        • BMCappelletti
          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
          by BMCappelletti
          Hi everyone.
          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
          02-18-2025, 12:22 PM
        • selectivetao
          Request for Boardview/Schematic - Biostar B660-T Silver Motherboard
          by selectivetao
          Hello fellows,
          I am putting a feeler out for a schematic (or ideally boardview) for the Biostar B660-T Silver motherboard.
          I had let my guard down and decided to trust the Biostar supplied Windows based BIOS flash tool, only to find that the system would not POST upon restart.
          no problem I thought - I would just flash using my trusty CH341 and be on my merry way.
          Upon inspecting the board and locating its Winbond NOR, I found it in a rather precarious spot nestled between the RAM slots and PCIe slot and right next to a rather meltable-looking...
          12-13-2024, 09:37 PM
          Biostar GeForce 6100 AM2 (CRU51-M2) Schematic
          Biostar GeForce 6100 AM2 Ver. 1.x is a motherboard based on the Nvidia nForce 410 (GeForce 6100) chipset....
          10-31-2024, 02:29 PM
