Gpu pins
  • laze
    • Oct 2023
    • Macedonia
    Gpu pins
    If someone could help me indentify pins that i marked on the picture
  • Yanleb
    Samsung UN58TU7000F no picture
    by Yanleb
    I have a Samsung UN58TU7000FXZC (same as UN58TU7000FXZA, just the Canadian model) with no picture. Backlight is on and sound is coming out just fine. Just no picture.
    What is frustrating is that there's no voltage test point and no component labelling of any kind.
    What I have found so far:
    1. No voltage at pins 91-94 of the 96 pins connector CN1300 (marked 1 on the picture). This TV set has no T-CON board. The 96 pin flex cable goes directly to the right (when facing TV) lower panel board. Itself is linked with another flex to the other side.
    2. Voltage...
    01-19-2023, 01:44 AM
  • SS454
    vizio e650i-a2 backlight flashes then turns off
    by SS454
    vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
    panel: au optronics T650HVN05.4
    72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
    link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
    Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
    https://www.shopjimmy.com/vizio-56-0...-power-supply/
    Vizio 55.75J01.001G (91.75J10.004G) Main Board...
    08-20-2020, 03:57 PM
  • Tr0ll
    by Tr0ll
    Original T-con:
    First replacement T-con:
    10-07-2023, 07:48 PM
  • TR103
    by TR103
    - it keeps rebooting
    01-22-2025, 04:12 PM
  • Mgiffune
    by Mgiffune
    06-09-2024, 10:28 AM
