Rx580 8gb sapphire nitro+ turn off vcore randomly
  • mikzs
    • Feb 2022
    • 5
    • aragua
    Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could be? I am currently changing the vcore driver for a 480 nitro, the gpu gives video but it does not load the drivers, I will try to put another driver in it again but for a 580 nitro+ 4gb
    12v:ok
    3v:ok
    5v:ok
    1.8v:ok
    Vdci:ok
    Vmem:ok
    Vcore:fail
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3597
    • slovakia
    Re: Rx580 8gb sapphire nitro+ turn off vcore randomly
    u should replace all mosfets in that phase. u must use scope to check if that phase work
    • mikzs
      • Feb 2022
      • 5
      • aragua
      I tried changing the vcore driver and I didn't get any results, the gpu gives the image and loads the drivers but if I run a benchmark it turns off vcore, I removed the mosfets from the line that had a shorted one and I limited the electrical consumption as much as possible and the frequency of the core and memories through bios to try using it with only one active voltage line that is only 2 mosfets and it generates the same error it delivers video loads drivers but it does not support putting load on it, maybe it is the core that is damaged? It seems strange to me that it turns off vcore and takes it to 0, it only happens when you put a load on it, it instantly turns it off or it does so after a few seconds (the PC is still on) and the way to make the video play again is by turning it off and on
      • DynaxSC
        • Apr 2021
        • 462
        • Poland
        Could be a problem with the over current monitoring network of the gpu vrm (driver). Look for missing or decalibrated components in this network. Another issue could be a thermal issue, eg. a non contacting joint GPU-board, DRAM-board, you could try a reflow/reball.
        • mikzs
          • Feb 2022
          • 5
          • aragua
          I tried to reflow the gpu core only since I don't have stencils to do the reballin work, the same error persists in terms of fallen components, it doesn't seem like something is missing, I was taking a short break while ideas arose, the only thing What comes to mind is to perform another reflow with a little more temperature since the previous one I kept it at less than 220 degrees Celsius
          • Swell61
            Sapphire Nitro+ RX580 8GB GPU 12V short
            by Swell61
            Hi
            I picked up a faulty Sapphire Nitro+ RX580 8GB. It was pretty clean, expect from what looked like residue around the thermal pad between the rear of the board and backplate for helping to cool the memory, so I am guessing it had some liquid spilled on it at some point. All I was told is "the screen went black when playing a game".
            The 12V external power appears to have a short. The two fuses have blown (circled in red on the image) and I am measuring low resistance (1.6 Ohms) on the output of the fuses to ground. When I inject power at the output of the fuses,...
            12-09-2024, 04:52 PM
            ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
            This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
            09-12-2024, 03:28 PM
            ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
            This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          • conghuyms
            MSI RX580 Vcore voltage is too high, please help me !!!
            by conghuyms
            I have an MSI Armor RX580 8GB V1.3 graphics card. Currently, all power rails are present, but the voltage supplied to the GPU Vcore, which should normally be around 0.9–1V, is measuring at 1.4–1.5V. The GPU gets very hot, and the MOSFETs supplying the Vcore phases are also extremely hot, with a noticeable whistling noise.
            I’ve already replaced the UP9505P controller IC with a new one, but the issue remains the same.
            Since the UP9505P is a new IC, could it require firmware programming like some high-end graphics cards such as the RX5700XT?
            What should I do...
            08-02-2025, 11:38 PM
            Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
            This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 04:10 AM
