Gigabyte GA-7N400 pro apparently dead
  • panegiricus
    • Oct 2010
    • 28
    Hi people, i ask you opinions about this board.
    Two years ago, it begins to run only cpu fan. I changed it , and only for curiosity, i tried to turn it on, but no life signal, cpu fan too. Apparently no caps is "poofed" . This is the caps list of this board:
    22 x 1000uF 6.3v Nichicon HM(M)
    3 x 3300uF 6.3v Rubycon MBZ
    3 x 1000uF 16v 105° FJ
    8x 100uF 10v GSC
    3x 22uF 25v GSC
    1x 10uF 50v GSC
    1x 100uF 16v GSC
    How can i test what's got wrong on this board? How can i test if mosfets or other are gone?
    Thanx in advance.
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Gigabyte GA-7N400 pro apparently dead
    I dunno, because GSC caps usually bulge when failed.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Prott
      Gigabyte GTX1080 - identifying a dead short on vmem
      by Prott
      Hey!
      I have a problem with Gigabyte Aorus 1080. The card seems fine (expected resistance on vcore, pex, 5v, 1.8v, 12v and reset) except for a dead short on vmem (FBVDD). It's interesting failure mode, cause usually (in my experience) when memory fails it still retains a few ohms - this one is literally a dead short.
      I removed the inductors and tried inject voltage (0.8 V at 6 A) which only seemed to warm up the cables to the card while the card itself didn't show any hotspots.
      Is there any way to narrow down the search for a short? I would prefer not to remove...
      07-04-2023, 06:29 AM
    • JimMc0
      Gigabyte GA-H61M-USB3-B3 dead short 3.3v rail to ground.
      by JimMc0
      Hi there,
      I discovered this forum through a youtuber who teaches electronic repair. I've been trying to troubleshoot my dad's old PC which is a Gigabyte GA-H61M-USB3-B3 and will not power on. I discovered a dead short on the 3.3v rail at the ATX connector so I used a bench power supply to feed 3.3v into the ATX connector and sunk about 400mA into the board (I hope that's not too much!). I used a FLIR camera to identify the problem area:
      The chip seems to be the following, an ITE IT8892E 1108-CXS which seems to be a PCI bridge?
      03-27-2024, 08:36 AM
    • DynaxSC
      GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
      by DynaxSC
      I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
      General test conditions:
      - Tested with Core i5 6500 and Core I7 6700K - no difference
      - Default BIOS settings, but tried also altering several memory setting - does not change anything
      What is wrong:
      With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
      When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
      03-21-2025, 06:23 PM
      Thermal pad thickness for various laptop GPU / Graphics Cards
      ASUS Dual RTX 2070 OC 8GB
      ASUS ROG STRIX RTX 3080 OC
      ASUS ROG STRIX RTX 3090
      ASUS TUF Gaming RTX 3080 OC Edition
      ASUS TUF GTX 1660 S-O6G GAMING
      EVGA RTX 3060 Ti XC GAMING 8GB
      EVGA RTX 3060 XC GAMING 12GB GDDR6
      EVGA RTX 3080 FTW3 ULTRA GAMING
      EVGA RTX 3080 TI FTW3 ULTRA GAMING
      EVGA RTX 3090 XC3 ULTRA GAMING 24GB
      Gainward RTX 2080 Phoenix GS Specs
      Gainward RTX 3070 Phoenix 8GB
      Gainward RTX 3080 Ti Phoenix
      GIGABYTE AORUS RTX 3080 MASTER 10G
      02-09-2024, 08:08 AM
    • nikovmiroslav
      Gigabyte A5 X1 Need Bios
      by nikovmiroslav
      Hi Everyone,I need help with this strange Gigabyte laptop,it turns on with black screen and after 30sec fans on the Max for few seconds and it shuts down,I think the bios is bricked,They say it is Clevo under the hood,there is nowhere on motherboard what is the model which is strange,i will write S/N and P/N from the motherboard,thats only what is writen there and upload old bios,if anyone can help,Thanks!
      Gigabyte A5 X1
      From motherboard:
      S/N: 1TNH55ER1350895
      P/N: 6-77-NH55ERQY-D02-2CGB
      On sticker from the back of the laptop:
      S/N: SN21351J000657...
      08-24-2025, 09:15 AM
