RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
  • T4H
    • Sep 2021
    • 9
    • Austria
    I have an RTX 2080 ti (Zotac - triple fan) with no video output.
    So far I have measured the following:
    • PS_FBVDD_PH3_SW = 40 ohm to ground (Micron ICs) - Memory should be fine right?
    • 12V power rail present
    • 3.3V power rail present
    • 5V power rail present
    • 1.8V power rail present
    • Vcore power rail missing --> PS_NVVDD_VREF is present. (from uP9512P / U812)
    • Vmem power rail missing --> Not there because Vcore power rail is missing.
    Any idea? I have already tried to flash the BIOS chip (backup got created) - sadly no changes.
    Source: https://www.techpowerup.com/vgabios/...emSize=&since=
    • Version: 90.02.0B.00.C7
      AND
    • Version: 90.02.17.00.58
    Note: GPU chip is getting hot when PC get turned on - Won't be recognized by MATS.
    MATS result - command: ./mats -e
    command: ./mats -e 5 :less only says "standard input".
  • T4H
    • Sep 2021
    • 9
    • Austria
    Re: RTX 2080 ti (Zotac - triple fan) - No video output / Vcore / Vmem missing
    Edit:
    Has anyone the boardview + schematics for the GPU mentioned above? I only have it from a MSI RTX 2080 ti.
      • 22035
      Originally posted by T4H
      Edit:
      Schematic requests go here - https://www.badcaps.net/forum/forumdisplay.php?f=15
      • Gigge@mail.com
        • Jul 2021
        • 3
        • Sverige
        Did you solve this problem ?
        • T4H
          Zotac RTX 2080 ti (triple fan) - schematics and boardview
          by T4H
          has anyone the schematics and boardview for the Zotac RTX 2080 ti (triple fan) 11GB?
          Thanks!
          08-21-2023, 02:48 PM
        • floodster1
          Evga Gtx 1080 vmem but no vcore
          by floodster1
          I have an Evga 1080 for repair.
          There was a short on the 12v and a burn hole in the bottom stage of the vcore.
          I cleaned it out and the short is gone.
          Iv checked all the resistance on the minor rails and there good.
          Voltages are.
          12v
          3.3v
          5v
          1.8v
          Vcore 0v
          Vmem 1.3v
          Pex 16mv
          I thought you need to have vcore or pex before vmem would turn on so it leaves me a bit confused.
          Iv looked at the vcore ic NCP81274 and I get
          Enable 1.8v low?
          Vcc 5v
          Vref 2v
          Pgood 0v
          I did some digging...
          08-20-2022, 07:16 PM
          NVIDIA GeForce RTX 2080 Schematic & Board View
          The GeForce RTX 2080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU104 graphics processor, in its TU104-400A-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU104 graphics processor is a large chip with a die area of 545 mm² and 13,600...
          10-02-2024, 07:57 AM
        • Thetechdude
          Repair help. Zotac trinity 4070ti 12G 3x
          by Thetechdude
          Hi Guys.
          Here I have a 4070ti with some issues.
          When powered on the led lights which power on (where the zotac logo is) flash green 3 times. Once it has flashed green 3 times it does not post.
          Just to mention I have not worked on many 40x cards before therefore some of my assumptions could be wrong. If you do happen to find that my analysis is wrong or I have missed something feel free to comment.
          Additionally, I do not have a schematic for this exact card model so if anyone is willing to post the schematic it would be much appreciated.
          Resistances:...
          09-07-2025, 07:49 AM
          NVIDIA GeForce RTX 2080 Ti Schematic & Board View
          The GeForce RTX 2080 Ti is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2018. Built on the 12 nm process, and based on the TU102 graphics processor, in its TU102-300A-K1-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2080 Ti. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU102 graphics processor is a large chip with a die area of 754...
          10-02-2024, 08:01 AM
