Asrock G41M-VS3 R2.0 - repair journey
  • N²x²N
    • Apr 2023
    • 54
    • Italy
    Hello again!
    I got this board but no power on. Tested the usual.
    https://asrock.com/mb/intel/g41m-vs3%20r2.0/
    Shorts on +5VSB/+5V/+3V at ATX. 0.7 ohm, not 0. Something is shorting all 3.
    Checked all the components after plugging PSU and found that the SB was very hot but bearable. Another smd, LM1117, responsible for the +3VSB to SB was instead ubearably hot (stick a finger and instantly feel the pain, warming everything in a 1/2 inch radius). I swapped it with another known working LM but still the same.
    Legs have the following readings: +5VSB ok, +3VSB 1.8V - not ok, third leg not ok either. Something was pulling V from the +3VSB.
    https://www.alldatasheet.com/datashe...MI/LM1117.html
    Desoldered LM1117 and the SB would just get warm, there's my short.
    My question: is the tiny ICH7 easy to desolder with just a heatgun? I'd like to experiment desoldering and maybe resoldering one from another dead board, and confirm it is the culprit.
    Thanks for any help!
    Btw, I have the schematics if anyone needs them. Or just look up for Asrock schematic diagrams.
  • N²x²N
    • Apr 2023
    • 54
    • Italy
    Re: Asrock G41M-VS3 R2.0 - repair journey
    No repair for this one.
    I desoldered the southbridge and the shorts went away. A heatgun with preheat from bottom worked. It took like 5 minutes though, sounding like chip killer having to go up to 350°C to actually remove it.
    A few pads came off but they were NC or GND. like 6/7 in all. Not bad for a first time.
    It's not economical to replace it, let alone doing the job on the no-room placement of the chip.
    Now it's a donor board for what's on it.
    Really interested in knowing how it could have happened.
    • Exim
      ASRock N100M, no picture no boot, but semi-alive
      by Exim
      Hi guys,
      I managed to semi-kill an ASRock N100M board after updating Bios from 1.10 to 2.01. It's a zombie now, dead, but not dead.
      ASRock N100M special features:
      - CPU soldered to board, small Intel 12th gen
      - iGPU
      - four POST LEDs
      Problem after updating Bios to 2.01 using the in-Bios update tool: no picture, no boot.
      I am not sure anymore if it booted at least once successfully after updating the bios to 2.01, maybe not, I can't remember. I think it did not.
      Symptoms:
      - no picture/signal on any of the display connectors,...
      04-01-2025, 02:36 PM
    • MasterCap
      What IC does AsRock usually use to make the PWM signals for GPU fans ?
      by MasterCap
      I have an AsRock Taichi 7900xtx, and the minimum fan speed is way too high at 1000rpm, and thats with it's Quiet BIOS switch on, and me setting the fan profile as low as it goes, while on.
      Now 1 thing I could do is just make some circuit to put in between the fan the the GPU, and leave the fan on all the time, but anytime the GPU is sending the PWM for min speed, I'll just send something lower and quieter.
      But does anyone know what how AsRock usually sends the PWM to the fans on GPUs and mobo's? Is it from the MCU that's often near the 12V inputs and fan jack ? Or is...
      12-28-2024, 08:42 AM
    • nolaryie
      BIOS .bin file for ASRock B450M Steel Legend
      by nolaryie
      Hi, I’m looking for a clean, working BIOS .bin dump (16MB) for the ASRock B450M Steel Legend motherboard.
      I’ve already tried flashing the official ASRock ROM file via CH341A, but it won’t post — I believe the capsule format is incompatible.
      Any BIOS version that supports Ryzen 5 2600 is fine (e.g., P2.30–P3.60).
      If anyone has a working board and can dump the BIOS using CH341A or flashrom, I would really appreciate your help.
      Thank you!
      08-06-2025, 12:01 PM
    • khanhtq0
      Full BIOS Dump for ASRock H310M-HDV Rev 1.02 (MX25L12873F)
      by khanhtq0
      I'm looking for a full BIOS dump (.bin) for the ASRock H310M-HDV Rev 1.02 motherboard. The BIOS chip is a MX25L12873F (128Mb / 16MB).
      I’ve already tried flashing the official BIOS from ASRock (version 1.40 and 3.30), but those are Instant Flash versions and don’t include the full SPI image (e.g. Intel ME Region, Descriptor, etc.). After flashing, the board powers on only when I short PS-ON to ground, and it fails to generate Vcore and 2.5V. Other rails like 1.05V and RAM voltage are present.
      I suspect the original Intel ME and descriptor...
      08-06-2025, 02:14 AM
    • zklgfs
      AsRock B560 Pro4 Possible Short on +1.8VSB
      by zklgfs
      I have an AsRock B560 Pro4 (boardview: https://www.badcaps.net/forum/troubl...pro4-schematic) that's completely dead (it doesn't even turn on the power supply when the power button is pressed or the power button pins are shorted). I do get about 3.4V on the power button pin, but 1.8VSB isn't there. The resistance to ground on the inductor PL53 is only about 0.1-0.4 Ohms. Am I correct in assuming that there must be a short...
      06-07-2025, 02:22 AM
