No Intel Management Engine (ME) version detected in bios
  • TheQuentincc
    • Mar 2017
    • 64
    • France
    Hi, I have a few different motherboard from different vendor and generation (Z77, Z87 and X99) that are "missing" the Intel ME.
    I successfully flashed the bios using an external programmer with the bios file directly downloaded from the manufacturer and verified the ME was present (in the file) with the "ME Analyser" python script.
    Then after flashing and doing a full clear cmos and so on I still have the ME missing (detected as "N/A") with some functionnality (depending on the board) missing such as frequency reading/overclocking and so on.
    I even read the bios chip again after the first boot and checked if the ME was present and it was, so the ME is really on the bios chip but the board refuse to use it...
    I speculate the chipset might be partly defective in those case, is it something really possible ?
    Thanks for the help
    • 21173
    Re: No Intel Management Engine (ME) version detected in bios
    Thanks for the help
    It could be a problem with the ME disable strap , or HDA_*** audio chip voltage. Have any of the PCH chips been replaced ?
    One thing you can try is to force a reset using intel FPT ,flash programming tool using the command FPTW64.exe -greset ,and install the Management engine drivers from the motherboard support site or from winraid https://winraid.level1techs.com/t/in...ols-2-15/30719
    • DynaxSC
      • Apr 2021
      • 466
      • Poland
      Hi, this is a difficult situation. As far as I understand the topic, the ME software needs to be programmed physically into the chipset's non-volatile memory to be working. If it's once happened to be missing in the chipset it needs to be reprogrammed again. Unfortunately I don't know a good universal method to do it. Only what I can suggest is how to do it for ASUS board's. I observed that programming the BIOS with the oldest version of the BIOS can help, as ASUS BIOS somehow checks if the ME is in the chipset, and if not it programs it into the chipset from the BIOS chip during the first run after the BIOS programming. A message is displayed in the left top corner of the screen, if you see this message you can be happy. Unfortunately this does not work with other vendors boards.
      There is also a topic about this on the Winraid forum:
      https://winraid.level1techs.com/t/in...sitories/30869
      There is some software and all of the ME versions available, maybe also a way for programming the ME, but I never got through this topic to understand how to program the ME, as it seems to be quite complicated. But maybe worth to look into.
      • Herbs n spices
        • Jan 2021
        • 36
        I had an X99 motherboard with the same ME version N/A issue. MEInfoWin64.exe -fwsts reported "Chipset ID mismatch". Easily solved by cleaning the ME as per the instructions on the winraid forum.
        This usually has to be done after you replace the PCH, but in my case it was because the BIOS chip had been swapped out with a different board. Possibly related: my X99 PCH was on the verge of failing as well.
        Guide-How To: Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization Last Updated: 2020-07-22 This guide is relevant to those who need to clean the DATA section of an Engine (CSME, ME, CSTXE, TXE) Region, which is part of a dumped SPI/BIOS image, in order to flash the latter on a different machine of the same OEM model. It is not meant as a guide on how to completely transform a dumped Engine region into a stock Intel-provided one. Although the guide can be used for that some...
        • DynaxSC
          • Apr 2021
          • 466
          • Poland
          On ASUS boards usually its enough to program the first stock BIOS version to enable the ME, there is no need to do such a comprehensive ME cleaning procedure. Then only thing left is to write the corresponding DMI data back into the image (must naturally do first a backup on the original BIOS).
          • DynaxSC
            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
            by DynaxSC
            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
            The board is generally working now, all PCIe ports are working, Windows installs normally.
            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
            03-10-2025, 12:27 PM
            by Vesko356
            08-11-2023, 03:27 AM
          • DynaxSC
            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
            by DynaxSC
            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
            06-10-2023, 11:30 AM
          • jbonavita
            by jbonavita
            Some issues
            Things I tried
            04-29-2025, 09:38 PM
          • zenius
            by zenius
            12-08-2024, 06:13 AM
