Biostar Geforce 6100-M9 weird problem
  • flinx
    • Aug 2010
    • 132
    Motherboard makes a noise like a camera flash charging (although erratically). Once the sound goes away. The fans spin up (without pressing the power button) but nothing else works (no beeps, no lights). I found 3 of the 5 3300uf 6.3v caps near the CPU are swollen. Replaced all 5 of them.
    Motherboard still does the exact same thing.
    Replacing the power supply gets the same results.
    "...off the record, unnamed government sources
    alluded to unsubstantiated innuendos about
    alleged indiscretions and insinuated that they
    are rumored not to be without basis for further
    speculation..."
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Biostar Geforce 6100-M9 weird problem
    You have the classic nVidia chipset failure. Reflow it by your favorite method. Infrared (best), hot air gun (cheap) or oven (ghetto). I've fixed a few boards with the oven method (but have switched to the hot air gun since), so if you want me to detail the procedure i will, but i think i already posted it here just a little while ago, try searching for my posts.
    A working TV? How boring!
    • flinx
      • Aug 2010
      • 132
      Pulled up all 58 of your posts. Did not find the procedure. Please post it again.
      speculation..."
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Mmm, that's strange. Anyway, here goes.
        Take board out, remove everything from it including chipset heatsink and ALL electrolytics. That is, if you don't fancy capacitor popcorn. On laptop mobos you can get away without removing any caps, coz they're all solid there, but on desktop boards and video cards you have to. If you don't... you'll be replacing them afterwards anyway.
        Take cooking tray out of oven. Cover board, except chipset, in aluminum foil. Make 4 foil balls of the same size, large enough so that the bottom of the board is at least 1cm away from the tray. Put foil balls on cooking tray. Seat the board on the foil balls, chipset side up.
        Preheat oven to 210C. Use multimeter temperature probe (they're good up to 400C don't worry), or infrared thermometer if you have one. Oven thermostats tend to be unreliable so monitor the temp if you don't want the plastic on SATA and IDE ports melting... I had that happen once.
        Put tray in oven. Close oven. Wait 7 minutes while monitoring temperature. After 7 minutes, turn off oven and open door. Let the board cool down to room temp, will take 30 minutes to an hour depending on room temp. Don't be tempted to pull the tray out so that it cools down faster, at this point the components are held by surface tension only, any bump WILL send parts flying. Just let it cool down on its own. Put all caps back in and boot 'er up. 90% chance of working.
        That's all. 210C, 7 minutes has always done it for me. 3 mobos, a couple video cards, and even a N73 cellphone board.
        • theknow
          • Mar 2011
          • 5
          hello I have the same problem but my motherboard dont work anymore in this image you woul see what i have made to make it work but its still dead pleas help me,
          http://img3.*************/i/june2010261.jpg/
          some parts of the motherboard get warm maybe it would give a clue of what is wrong but i have no idea.. i will thanks a lot bye
            NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
            The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
            10-02-2024, 08:52 AM
            Biostar GeForce 6100 AM2 (CRU51-M2) Schematic
            Biostar GeForce 6100 AM2 Ver. 1.x is a motherboard based on the Nvidia nForce 410 (GeForce 6100) chipset....
            10-31-2024, 02:29 PM
            NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
            The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
            10-02-2024, 07:51 AM
            NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
            The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
            10-01-2024, 01:54 PM
          • chaos-theory
            Nitro rx580 very weird problem, VCORE and EN
            by chaos-theory
            Hello!
            I have this very weird problem, I got this rx580 nitro saphire and the fans don't even spin but the saphire logo is lit.
            All voltage rails are present except for VCORE at the coils, then I started checking NCP81022 and it has voltage but vdd pwrgd is missing, enable EN is missing it shows 2.5ohm, everything seems fine, i tried checking the back of the card, to see where the enable pin goes, i dont have a schematic so i started touching randomly until i measured a resistor on the back and the fans started spinning, now I was amazed like what is wrong here? So I thought it's a...
            08-17-2024, 04:56 PM
