EP-8RDA3+ Bad caps
  • sticky
    • Nov 2005
    • 8
    EP-8RDA3+ Bad caps
    I have a rev. 1 and my vdd has been flaking out lately. Does anyone know what caps i would have to replace to correct this?
    Thanks.
  • MD Willington
    • Sep 2004
    • 702
    Re: EP-8RDA3+ Bad caps
    Should say right on the capacitor...
    Ya'll think us folk from the country's real funny-like, dontcha?
    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
    • sticky
      • Nov 2005
      • 8
      Thanks. Do you know if i would mostlikely be able to purchase them at Radioshack?
      Thanks again.
      • AK0R
        • Mar 2005
        • 204
        No. You need low ESR capacitors for a good, stable motherboard. You won't find those at Radio Shack.
        Use the Search function, and search for your motherboard model. There have been several posts written on it.
        You can also find all the information you need about which caps need to be replaced, and what sources provide usable replacements.
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
