House wiring
    Re: House wiring
    Originally posted by smason View Post
    Zoneminder ROCKS! And it's free. It will also work with IP cameras, and wireless IP cameras, even cheap USB webcams.
    Sweet, I see that they even support some wireless IP cameras we already have (ABS Megacam 4220). Will definitely check into using this.
    A good dual shield RG6 is fine, quadshield is ok, but overkill. I use dual shield for 60 foot runs of Gigahertz sat feed, and it's fine.
    Overkill isn't bad sometimes; we plan to stay in the house until retirement, and who knows what kind of technology will be out by then that may be able to take advantage of better wiring.
    Those On-q, and Leviton all-in-one boxes are waaaay overpriced, that's why that builder "swears by them" huge markup Just get a standard 110 patch panel and a decent switch.
    Cat 6 for phone is overkill, but I always recommend it, as you can switch to data later, or VOIP without having to re-wire.
    I kind of figured that; these types of systems are high margin even taking the labor into account. We've already told the builder we'll be doing our own wiring along with the hardware. We'll let them concentrate on actually building the house! Thanks a lot for your insight, it seems we have a bit more research to do.
      Re: House wiring
      Originally posted by ratdude747 View Post
      do quadshield, if you ever do satellite, you need it, 1000mhz is for digital cable only. dualshield is harder to find as well. swapping splitters is much less of a paint than swapping cable... do it right the first time.
      Totally agree with this; the cost difference ($50?) is worth it in my opinion.
        Re: House wiring
        partly right.. standard RG6 starts at duel shielding.. Here that is very easy to find.. If you are going to want the better stuff, I would more watch toward getting solid copper cable instead of copper clad (copper coated steel "center data wire only"). The copper clad will work, but the solid copper is more flexible, and because of it being a solid copper core wire, it has less signal drop..
          Re: House wiring
          i only use 6.6mm oxygen-free copper core with copper foil wrap + copper braid.
          the loss figures on that are tiny.
            Re: House wiring
            Thanks guys, I will keep that in mind when I start shopping. Speaking of shopping, I started looking at prices for Cat6 and Cat6A... I can't believe Cat6A is 3X more expensive! I wonder how much a few thousand feet of fiber (and related equipment) would cost.
              Re: House wiring
              Depends on if you want single mode or Multi-mode.
                Re: House wiring
                Not only...damn those specialised equipment needed to terminate fibre cables!
