No shares within a workgroup appearing
+ More Options
Posts
  • japlytic
    • Oct 2005
    • 2086
    On a new Windows 10 install, I cannot see other computers on the network even though I am on the correct workgroup name despite seeing other network devices which do not use a workgroup and that network discovery is enabled and set for a private network.
    I then discovered something in "Turn Windows features on or off" which was "SMB 1.0/CIFS File Sharing Support" which enabling it fixed this problem.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: No shares within a workgroup appearing
    This is disabled if you select 'public network' as network type.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • seanc
      • Nov 2008
      • 1319
      SMB 1 is disabled by default with build 1803.
      Access to C$ or admin$ is also disabled unless you modify localaccounttokenfilterpolicy.
      https://support.microsoft.com/en-gb/...y-registry-se/
      • japlytic
        Maximum speed should be marked on network ports
        by japlytic
        I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
        One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
        12-19-2024, 05:04 PM
      • harp
        simple win network with optimization issue
        by harp
        simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
        06-23-2025, 11:01 AM
      • BOSCHNJAK
        by BOSCHNJAK
        ABOUT ME INTRODUCTION FILE
        2
        024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
        2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
        2022 BEV, PROJECT ?
        2021 BEV, PROJECT ?
        2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
        2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
        12-28-2023, 02:09 PM
      • sdogs
        Macbook Pro 16 A2141 stuck in network boot
        by sdogs
        Good evening guys ;-) In a moment of lucid madness I bought a macbook pro 16 A2141 on which they sat on it. Aside from the banana shape and obviously gone screen, the macbook turns on, sounds the initial gong.
        I disassembled the screen and connected it to an external display, using a usb-c adapter, but I can't reinstall the os.
        I tried SMC and PRAM reset but the result doesn't change, the recovery starts only from the network, I tried different USB pendrives with different operating systems but nothing, it sees the boot device for an instant and immediately goes looking for the network....
        02-25-2023, 11:27 AM
      • davg
        Home network connection problem
        by davg
        I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
        03-06-2021, 07:13 AM
