No shares within a workgroup appearing
  • japlytic
    • Oct 2005
    • 2085
    On a new Windows 10 install, I cannot see other computers on the network even though I am on the correct workgroup name despite seeing other network devices which do not use a workgroup and that network discovery is enabled and set for a private network.
    I then discovered something in "Turn Windows features on or off" which was "SMB 1.0/CIFS File Sharing Support" which enabling it fixed this problem.
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16951
    Re: No shares within a workgroup appearing
    This is disabled if you select 'public network' as network type.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • seanc
      • Nov 2008
      • 1319
      SMB 1 is disabled by default with build 1803.
      Access to C$ or admin$ is also disabled unless you modify localaccounttokenfilterpolicy.
      https://support.microsoft.com/en-gb/...y-registry-se/
      • japlytic
        Maximum speed should be marked on network ports
        by japlytic
        I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
        One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
        12-19-2024, 05:04 PM
      • BOSCHNJAK
        by BOSCHNJAK
        ABOUT ME INTRODUCTION FILE
        2
        024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
        2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
        2022 BEV, PROJECT ?
        2021 BEV, PROJECT ?
        2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
        2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
        12-28-2023, 02:09 PM
      • sdogs
        Macbook Pro 16 A2141 stuck in network boot
        by sdogs
        Good evening guys ;-) In a moment of lucid madness I bought a macbook pro 16 A2141 on which they sat on it. Aside from the banana shape and obviously gone screen, the macbook turns on, sounds the initial gong.
        I disassembled the screen and connected it to an external display, using a usb-c adapter, but I can't reinstall the os.
        I tried SMC and PRAM reset but the result doesn't change, the recovery starts only from the network, I tried different USB pendrives with different operating systems but nothing, it sees the boot device for an instant and immediately goes looking for the network....
        02-25-2023, 11:27 AM
      • davg
        Home network connection problem
        by davg
        I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
        03-06-2021, 07:13 AM
      • Rofix
        Asus H110 M-K network card problem
        by Rofix
        Hello I wanted to kindly ask for advice or this Asus H110 M-k motherboard, which unfortunately does not detect the network card to connect to the internet, I checked some voltages on the REALTEK8111-CG chip, on pins 11, 23, 32 I found 3.3 V
        Thanks to everyone in advance for any advice​...
        11-22-2024, 05:24 AM
