Netflix VR dropping back to Who's Watching
  • japlytic
    • Oct 2005
    • 2086
    I had problems where Netflix VR randomly drops back to the "Who's Watching?" screen without an error message, and I happened to catch a network error message when I tried to sign in at one time, which meant it was not related to overheating but a problem with the network.
    The network problem was traced to roaming between two associated wireless networks during streaming resulting in a dropout when transitioning between wireless networks, so I removed an associated wireless network from my device and the problem was fixed.
    Still wondering why Netflix VR does not give an error message when the network drops out...
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Netflix VR dropping back to Who's Watching
    IIRC, LOL, reminds me of some PC programs that use the loopback network interface for one portion to talk to another (literally 127.0.0.1, IIRC) and if there's a problem connecting to 127.0.0.1, IIRC, it will just keep bouncing back to the loading screen, IIRC.
    Racer (racer.nl) is one of those, IIRC.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • davg
      Home network connection problem
      by davg
      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
      03-06-2021, 07:13 AM
    • japlytic
      Maximum speed should be marked on network ports
      by japlytic
      I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
      One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
      12-19-2024, 05:04 PM
    • harp
      simple win network with optimization issue
      by harp
      simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
      06-23-2025, 11:01 AM
    • BOSCHNJAK
      by BOSCHNJAK
      ABOUT ME INTRODUCTION FILE
      2
      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
      2022 BEV, PROJECT ?
      2021 BEV, PROJECT ?
      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
      12-28-2023, 02:09 PM
