Configuring DHCPv6 on a Spectrum Ubee cable modem.
+ More Options
Posts
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I have a Ubee cable modem that I rent from Spectrum (formerly TWC). It has a DHCPv4 and a DHCPv6 server on it that hands out the IPv4 and IPv6 addresses (respectively). I noticed the addresses from the DHCPv4 server are private. I configured it for the 192.168.2.0 network. I started the pool at 20. I setup some of my clients (printer, Linux box, laptop, gaming consoles, etc) as static.
    Then I noticed the DHCPv6 server is handing out public IPv6 addresses. I'm still a bit confused with IPv6 but I'm slowly learning. I wanted to know if it's possible to configure that server to hand out unique-link addresses, from the fc00::/7 network, without anything breaking.
    For example, I see in the cable modem's UI System Delegated Prefix and it has the IPv6 global link address (the public ones). I can change that to a user delegated prefix (fc00::/7). I can change what address it starts handing out the IPv6 addresses as. But will this prevent me from accessing the internet with IPv6?
    With IPv4, I had to configure the gateway to the private IP address of the cable modem (192.168.2.1). The cable modem doesn't have a DNS server running on it, so when it was set to DHCP, I saw what it had setup for the DNS servers (dns1.rr.com, dns2.rr.com, etc) and I configured my Linux box to use those DNS servers. Will I have to do the same with the IPv6 stuff?
    I've tried searching the internet but I couldn't really find a lot of stuff on doing this with OpenSuSE. I can't really find much about the IPv6 and the Ubee modems, at least I couldn't find anything about what I'm trying to do.
    Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Configuring DHCPv6 on a Spectrum Ubee cable modem.
    I think I can do this. I noticed under the Basic >> Setup page, where it lists the DNS servers, it only lists IPv4 DNS servers. The IPv6 DNS server place is blank. From what I can tell, I cannot configure the DNS servers of the cable modem. But I don't think that will be a problem. I think I just need to manually change the IPv6 DHCP System Delegated Prefix from the public IPv6 address prefix to a private one. Then I need to change the pool so it starts giving out addresses starting at something like fc00::20/7. Then I need to configure my PCs and tell them where the gateway is and point them to an IPv6 DNS server and nameserver, preferable owned and operated by Spectrum.
    • Spork Schivago
      • Mar 2012
      • 4734
      Eh, it doesn't work. I change the System Delegated prefix to the fc00::/7 but it doesn't update the
      LAN Delegated Prefix, which is grayed out. It says above the LAN Delegated Prefix:
      Code:
       Server Settings
       LAN Delegated Prefix will be derived from System Delegated Prefix and Start Address will have the same prefix as the LAN Delegated Prefix.
      But changing the System Delegated Prefix doesn't change the LAN Delegated Prefix. And right now, my system is configured to pull an IPv6 address from the DHCPv6 server on the cable modem. It's still pulling the global (public) ones. Maybe if I restart the cable modem, but I doubt it.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8682
        DHCP6 normal mode is very well tied into the uplink IP address for 6rd/6on4/etc., so chances are a lot of GUIs hard codes the address as they're not expecting people to use local unique addresses. What is your v6 provider?
        Another issue is if your router set up for NAT6? If not, even if you get DHCP6 local unique address, it won't route them.
        If the router is firewalling V6 packets properly, it should not be a security problem to use the global v6 addresses... What problem are you seeing with the global v6 addresses? Just privacy?
        • Spork Schivago
          • Mar 2012
          • 4734
          Our provider is Spectrum. I don't know if the router is setup for NAT6, because the router is built into the modem, and it's a bit limited. But I think it is. I noticed the addresses they hand out for the DHCP is different than the IPv6 WAN address they list in the page. The first four groups are different. So I think it'd have to be doing some sort of NAT6, wouldn't it?
          The firewall is the biggest issue and the main reason was privacy. Our only options for the firewall are, "low", "medium", "high". If we had shell access, maybe we'd have something like iptables and we'd be fine. We have some options, like block WAN ping, but if we do that, we cannot ping anyone (probably it's blocking the ICMP-reply). My wife runs Windows 10 on her laptop. I think having that hooked directly to the net is probably a horrible idea.
          I was thinking of maybe looking into setting up a Linux box as a gateway and configuring iptables on there. The box would be in the DMZ but if I have the firewall properly setup, security shouldn't be an issue.
          • Spork Schivago
            OpenWRT, Spectrum DOCSIS 3 Cable Modem and IPv6 addresses.
            by Spork Schivago
            Hello!
            So I'm working on setting some stuff up, and long story short, I put my Spectrum rented cable modem in Bridge Mode and disabled the wireless. Then I took this cheap Vizio router I have, and a while back, I was able to get OpenWRT compiled on it. I think I'm the only one who has done this, because the flash size is very small and I'm extremely limited to how many features I can use.
            But for experimental purposes, I'm using the Vizio OpenWRT router. I've setup wifi on it, and the WAN parts are working as expected, the WAN port is being assigned the public IPv4...
            04-05-2018, 12:35 PM
          • dahm
            tenda v12 ac1200 modem
            by dahm
            please need me tenda v12 ac1200 modem bios dump 8mb
            05-23-2025, 12:15 PM
          • tknox11
            Miller Spectrum 375
            by tknox11
            Anyone familiar with what this part# may be complete? Its on a Miller Spectrum 375 plasma cutter board, Q6 is the location on the board....
            02-19-2025, 11:00 PM
          • rbvndonh
            Lenovo T440s 1802 WWAN modem error
            by rbvndonh
            I had factory installed Ericcson modem. It was working, but later was changed into Dell 4G modem. It was working good.
            Now, after BIOS repair (to the same which was rapaired in past in this machine) it shows 1802 error.
            Does somebody have whitelist or know how to correct it or proper no-1802 tool or solution for this board?
            Thank you
            12-04-2022, 01:09 PM
          • playit
            broadband ut300r2u modem,link light stays on forever
            by playit
            ut300r2u modem,link light stays on forever no matter if if dsl phone wire connected or not.i dint mess with any firmware ,it started to be like this for past few months until it stopped all together to work anymore,so learned that flashing might help, need dump file for this modem, i have only ch34a1 programmer.so i erased and flashed with few bin or ras files i got from internet but nothing worked.so further reading let me know that have to flash a whole full dump .if any idea, pls share, thank you.
            08-11-2022, 01:44 AM
