Anyone familiar with what this part# may be complete? Its on a Miller Spectrum 375 plasma cutter board, Q6 is the location on the board.
Miller Spectrum 375
by tknox11Does anyone familiar with what this full part# is? Its off the mainboard from a Miller Spectrum 375 plasma cutter, component location Q6. Thanks for any help guys!1 Photo
by CapLeakerHmm… someone brought me this Miller Diversion 165 TIG welder for repair. Claim is it doesn’t arc. Well it tries doing something if I put the tungsten tip straight to the aluminum plate. All I hear is a little tick… tick… tick…, I have the power LED on, but the other (blue?) LED doesn’t light up. I think it is supposed to when there is an actual arc.
So I opened it up, found a bad looking connector between the main board and the small HF board. Checked the SCR and few other things on it and found nothing. Then tried again. Same thing. I will not for its own life strike... -
by tarikabakHello, one of the vrams of my palit rtx 3060 model graphics card is showing as faulty. I will replace the faulty vram with a new one, but I could not find out the locations of the vrams. Does anyone know the location map such as a0, a1, b0, b1?
mats version 455.127. Testing GA104 with 20 MB of memory starting with 0 MB.
Memory Errors on
Read Error Count: 0
Write Error Count: 410022
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
------- ----------- ------------ ------------...1 Photo -
My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
- I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
- I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
- I could only locate two chips that look like bios chips. Could someone verify this
by DELLS DEALSHello Everyone I hope you are all okay I'm just looking for the location of the bios on the hp probook 445 g9 please if you could help id be very grateful I brought a flasher that clips on to the chip I just can't find the chip unless I ain't installed the drivers for the flasher properly. Any help would be brilliant if you have a diagram that would be great. I Look forward to hearing from you many thanks Dom Noonan
Channel: BIOS Requests ONLY!
10-29-2024, 05:04 AM -
- Loading...
